Engine
audiobliss
audiobliss Posts: 12,518
Hey everybody
I don't know about any of y'all, but I really love cars, engines; anything with wheels. I just had my first experience of 'working' on an engine this evening. We have an old gas edger that I started taking apart last year and put aside due to lack of time. Well, Mom said yesterday that I should put it back together so we could use it. However, I totalled the diaphragm in the carburetor (actually, I threw it away last year :D ) and broke off a screw in the engine block.
So, tonight was dedicated to ripping it apart, seeing how it works, and havin' fun!!! This baby won't cuttin' much of anyting anymore, I'm afraid...:D
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
  • audiobliss
    edited May 2004
    the welcome mat...in the garage...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    bad pic of the crankcase...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    ok..THIS is the crankcase...:D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    the header and gasket....must be a really high-compression engine...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    the crankshaft, wrist pin, connecting rod, pushrods, and some of the w/e thing-ma-jiggy that provides the electricity for the spark plug...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    finally, the piston and same thing-a-ma-jiggy
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    Boy, that was a lot of fun. It's really amazing to think of all that goes on in an engine, and that there are so many engines out there doing all that and that we hardly ever have any problems with them.
    Everything was ground so smooth, too!! This was really awesome. Hope somebody appreciates the pics.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • Jstas
    Jstas Posts: 15,001
    edited May 2004
    You should put it back together, you'll learn more that way. Get yourself a small-engine repair manual. Should show you how to basically go about it.
    The engien may have trouble running again though. It looks like an air-cooled 2 stroke but that piston looks burned. I can't see the valve but the combustion chamber there looks caked pretty good. Probably a couple of hot spots there causing a misfire or detonation. Not exactly good. I don't know how old it was but teh exhaust valve seat is probably burned pretty good too. Might be cracked/warped. Then again this is all from the pictures whichdon't show enough detail. Not your fault though. It's be better to look at it in person anyway.
    BTW, that thing-a-ma-jiggy is the ignition coil and it looks to have crank-triggered ignition. If you look in the closeup of the cranckcase picture you can see the gear that looks like it triggers the ignition firing. It's in the half of the crankcase, on the right side of the pic. The only white gear there. I could be wrong though. Like I said, it's hard to see the pictures.
    Expert Moron Extraordinaire
  • audiobliss
    edited May 2004
    jstas
    The ignition coil!! That's what ya call that!! And I wondered what that plastic gear could be doin'.
    Yeah, the pics are misleading. The edger is pretty old but probably wasn't used more than 10 times. It is an air-coiled 4-stroke. The piston is fine. The crankcase is fine. The valves are fine. It really is a shame to have to get rid of a perfectly fine edger.
    Actually, I had already ruined the diaphragm in the carburetor, and I got a screw stuck in the block, and Dad tried getting it out with a left-handed bit but ended up takin' a chunk out of the block. So, it was pretty much trash and I thought I could waste one evenin' havin' fun and seein' how complicated the whole thing is (was).
    Unfortunately, I can't put it back together. I would love to, but Mom wants it gone since it won't work. I don't have anywhere to work on it or the time; just happened to have tonight. Bummer. We'll be getting a new edger in a few days/weeks/maybe never.
    Thanks for tellin' me what that thing-a-ma-jiggy was and what the gear does (did).
    audiobliss
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    Wow; the piston really does looked burned in the photo; hadn't noticed it. I'm pretty sure that stuff just wipes right off, though.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dave shepard
    dave shepard Posts: 1,334
    edited May 2004
    I have a 425hp-350ci Chevy (4 bolt main) bored and stroked to a 383ci (complete) prof. built never off the stand for sell, that will get the grass trimmed :D .
    Dave
  • wlrandall
    wlrandall Posts: 440
    edited May 2004
    Actually, the "ignition coil" is a magneto. The higher the RPM, the hotter the spark. Used in all Top Fuel and Funny Car engines. If you notice there is no supply voltage to the coil; the permanent magnet in the flywheel creates the voltage pulse.
    I don't think it looks all that bad, really. Typical Briggs and Stratton is my guess. They all get nasty carbon buildup and have very uneven burn, hence the spots on the piston crown. Very durable engines, but even moreso inefficient.
    I'd do as jstas said, get a repair manual and throw it back together as it is the best way to learn. Looking at the crankcase I don't see any "chunks"; probably have a good number of hours left in it.
    Wally
  • wlrandall
    edited May 2004
    Dave
    Stop it, Dave, you're tempting me!!
  • audiobliss
    edited May 2004
    Dave
    Wow!!! Now, hw could you have an engine like that not be tempted to put it in something and go cruisin' every day?!?! Surely you have something comprable to that in a car, right?
    Reminds me of my dad's friends car: a beautiful black '69 Camaro with a 454 block, 427 heads, and everything else suoped up for drag racin'. Racing radiator, ignition, fuel cell, wheels/tires, roll cage. It's absolutely awesome.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dave shepard
    edited May 2004
    I had spent a couple years completly redoing a '57' Chevy inside and out and did the car first and the engine last before I got the engine in a person from NY heard about it and made me an offer I couldn't refuse (even went as far as to call me at a friends house to talk about it) but couldn't afford the engine so he got the car less the engine and trans. All I have now are the pics of the car as it was being loaded on the new owners trailor. I can post pics if you'd like to see them.
    Dave
  • audiobliss
    edited May 2004
    Would I like to see 'em?!?!?! Yes!!! About the only thing I"d rather have than a '57 Belair would be a late 60s Camaro. Or Lamborghini. Or Ferrari. Or Grand National. Or GTO. Or Ford GT. Well, I still like the '57 Belairs a lot. :D
    Do you also have a transmission, or did he buy the car before you got it??
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    And, can't ya squeeze out a little more than 425 from a 350?? What all do you have on it? A four-barrel? 2 of 'em? Let's see, you said it's bored and stroked, did you shave the heads? Is it really high compression? I reckon everything back then was 2 valves per cylinder. How much torque'll that thing make??
    Thanks,
    droolin' one
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited May 2004
    Dave
    What do you mean by '4 bolt main'? I've never heard that before.
    Also, I referred to my dad's friends " '69 " Camaro?? My bad; it's a '68. Had a momentary lapse.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • dave shepard
    edited May 2004
    I will put the pics up as soon as I can get them together. Yes I still have the trans it's a 350 turbo with a shift kit (hits very hard in every gear).
    Dave
  • dave shepard
    edited May 2004
    Thanks,
    droolin' one
    Yes one can get more then that from it, mine has cast 194 heads that have been completely gone over and trued (not shaved) the block was 0 decked for trueness and that raised comp. slightly my goal was to put a pair of Summit cast 202 or 205 (can't remember off hand) heads with all the goodies but time was a factor that would have given it an extra 60hp on hi-octane pump gas. The compression I can't remember exactly off hand but it was built around running pump gas and power accesories (cam, manifold etc) is matched to start putting out at 2500-3000RPM for the street (pole to pole not flat out high speed). The cam is one under needing a vacume canister (for power brakes) so it will have a loppy idle (enough to let everyone know DON'T GO THERE!!!! :D ). The tourque should be in the neighborhood of 450 flb. I got the 4-barrel 750 edelbrock but it really should have a 4-barrel 650 since I went with 194 heads.
    Dave
  • dave shepard
    edited May 2004
    Four boult main means that the caps that hold the crank in place have four bolts (much sturdier under higher power, tourque and RPM conditions) instead of two bolts that hold the caps. Some say that really doesn't make that big a diff. but I say why risk disaster for a few more $$$ you can cover all your bases by having a little more meat holding the bottom end from falling to pieces when the need arises.
    Dave
  • dave shepard
    edited May 2004
    Hear she is, all the work I did in the garage myself. I took the whole car apart piece by piece.
    Sorry bad pic removed :(
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
    hears the engine that's still in the garage.
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
  • dave shepard
    edited May 2004
