For Sale Brand New QSC K12.2 K.2 Series 12" 2-Way 2000 Watt Powered Speaker
Configuration Multi-purpose, 2-way powered loudspeaker
Transducers LF Transducer: 10" / 254 mm, cone
HF Transducer: 1.4" / 35.6 mm titanium diaphragm compression driver
Frequency Response Frequency Response (-6 dB): 56 Hz - 20 kHz
Frequency Range Frequency Range (-10 dB): 50 Hz - 20 kHz
Nominal Coverage Angle 90° Axisymetric
Maximum SPL 130 dB @ 1 M, peak 124 dB @ 1 M, continuous
Amplifier Class-D
Peak: 1800 W (LF), 225 W (HF)
Cooling Low-noise, variable speed fan
Controls Power switch
Level Dial: 3
Rotary encoder (push)
Selection Buttons: 2
Indicators Monochrome LCD Display 1.8 x 1.0" / 45.0 x 25.4 mm
Power LED (Front and Rear): 2
Input Signal LED: 3
Input A Mic selected LED
Input B Hi-Z selected LED
Limiter active LED
Connectors Mic/Line Input and Hi-Z/Line Input: 2 x locking XLR/F 1/4" / 6.35 mm combo
Stereo Input: 1 x 1/8" / 3.5 mm TRS
Loop-Thru Output: 2 x XLR/M
Mix Output: 1 x XLR/M
Power Connector: 1 x locking IEC connector
Power AC Power Input: Universal power supply 100 - 240 VAC, 50 - 60 Hz
AC Power Consumption (1/8th Power): 100 VAC, 2.1 A / 120 VAC, 1.9 A / 240 VAC, 1.1 A
Enclosure Characteristics Enclosure: Impact resistant ABS
Attachment Points: 2 x M10 threaded inserts plus pull-back
Color: Black (RAL 9011)
Grille: 18 Gauge powered coated steel, internal cloth lining
Regulation Compliance CE, WEEE, UL, China RoHS, RoHS II, FCC Class B
Dimensions (H x W x D) 20.4 x 12.6 x 11.8" / 518.2 x 320.0 x 299.7 mm
Weight 32.0 lb / 14.5 kg
Packaging Info
Package Weight 38.8 lb
Box Dimensions (LxWxH) 22.0 x 17.5 x 16.5"
For order placement and more information kindly contact us through the following below.
E-mail : otownborn@gmail.com
E-mail : gskconsults@gmail.com
    treitz3 Posts: 20,017
    SPAM.
    This is now a free service brought to you by Polk Audio. Click onto any link to add more free stuff you will want like adware, malware and other exotic viruses you can't get anywhere else! Who knows, some prince may even contact you telling you that you have great sums of money heading your way shortly...
    Good times.
  • GlennDog
    GlennDog Posts: 3,152
    treitz3 wrote: »
    SPAM.
    Who knows, some smok’n hot princess may even contact you telling you that you have great sums of money heading your way shortly...
    Patiently waiting :D
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Strong Bad
    Strong Bad Posts: 4,278
    I'll take TWO. Charge them to F1Nut's account.
    No excuses!
