SDA 2B: One speaker louder than the other
Airplay355
I'm using a pair of SDA2B (completely unmodified) with a Rotel RX-1050 receiver. One speaker is 2-3DB louder than the other. I've swapped the left and right to confirm the right speaker is the louder one so it shouldn't be the source (a Macbook) or anything on the receiver. I confirmed the difference with a pink noise test tone and DB level app. Not the most scientific of ways but good enough to confirm that I'm not a total nut with one blown out ear.
What would cause this? I don't ever remember them sounding like this before. I don't think it's room acoustics as they're in a very square bedroom.
Could be a bad mid-woofer. You can test by momentarily connecting a 1.5 volt battery to the speaker terminals and watch to see if they move.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
Just a thought. Did you try clean the contact where your speaker cables/wires hook into your receiver. Also keep in mind 30+ year old speakers may need refresh on crossover parts. Hope u find issue-feel your painRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Is the setup behind both speakers the same, or different? For example, is one speaker close to a corner, and the other near a hallway.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
DeletedRandy-Maine
by David WMG
Setup behind both speakers is completely identical. I thought first maybe it was because one wall has a window and that speaker was louder. After the speaker swap, that windowless side is louder.
Would it have to be the SDA driver that's bad? Both drivers seem like they're making sound just fine without any obvious crackling or anything and move freely when I push in the PR.
I haven't tried cleaning anything receiver side but figured since the quietness is following the left speaker and not the left side the receiver/source were fine. Am I thinking about that wrong? If the left speaker is swapped to the right, then the right side isn't as loud. If I swap them back, the left side isn't loud.
Could I check out the crossover and see if anything is damaged by removing the PR? Do crossover bits slowly go bad? I was expecting something to go all at once and I'd lose the tweeter completely or something like that. -
The electrolytic caps in your speakers are at least 30 years old, way past their lifespan. So, logic dictates that is likely the problem. Swap crossovers and if the issue follows it's time to upgrade the components.Political Correctness'.........defined
President of Club Polk -
I had hoped that wasn't the issue since everything seemed to work fine (until now) even though I knew the components are old. Thanks for the XO swap idea. I'll try that and see how it goes.
Everything wears out over time. Especially mechanical/electronic gear.Lumin X1 file player, Westminster Labs interconnect cable
Look at the bright side, if you liked them as they were, they are only going to get better with any mods you do
. It's not even worth considering NOT doing. So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
Trying to take the XO out of the left speaker. It seems like there's a bolt/screw holding it in place. I've tried loosening the screw and it just spins. I've tried spinning the XO while holding the screw and it just spins.
Am I doing something stupid? -
The glue holding the nut has failed. You'll have to remove the crossover board from the 4 standoffs, then use pliers or the like to hold the nut while unscrewing the bolt. Once you have everything apart resecure the nut with epoxy and wait a day before reassembly.Political Correctness'.........defined
Could this be a non common ground amp issue?Polk Audio SDA SRS 2.3 TL
Polk Audio SDA 2B TL mod
Carver M 1.0 MK2 Opt 2 x2
Carver CT Seven Preamp
Bluesound Node 2i -
Doubtful. If all your drivers and tweeters are working and speaker cables are not out of phase and everything else has been eliminated I'd follow @F1's advice and refresh the crossovers.Gustard X26 Pro DAC
