Parasound HCA 2205a Breathing Room
Bgoodfella
in Electronics
Hey guys - how much breathing room do you give your HCA 2205A amplifiers(for those of you who have this amp)? The manual is calling for 6" of room on the sides - but is that from the amp or from the heat sinks, and is that on each side - or 3 inches on each side for a combined total of 6"?
(2) Rti A7's
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Monster 850i interconnects ( not sure what everyone hates about these - maybe my untrained ears are too innocent to know what's bad)
Parasound HCA2205A amplifier
Sony XBR65X900E TV
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Sony XBR65X900E TV
6 on each side, the amp runs warm so you need some circulation around it.HT SYSTEM-
lsi 9's -
dang thats a bit of space required, do you know if the denon AVR x4300h will be ok in a cabinet - if i am using the parasound to power all of my speakers?(2) Rti A7's
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Sony XBR65X900E TV -
Your Denon should be fine in a cabinet so long as its got some room to get air.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
awesome, maybe ill move the denon in the cabinet so the parasound can have all the room in the world. when you say it gets pretty warm - how warm are we talking? will it burn you from touching it? (ive got little rugrats that are the right height)(2) Rti A7's
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Put one of these on the denon just to be safe:
https://www.amazon.com/gp/aw/d/B00G05A2MU?psc=1&ref=ppx_pop_mob_b_asin_titleLiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I like it! I'm assuming on top of unit correct?(2) Rti A7's
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Would there be any benefit to throwing one in the top of cabinet to pull out warm air as well?(2) Rti A7's
(1) CSI A6
(2) FXi A6's
Denon AVR - X4300H
Bgoodfella wrote: »Put one of these on the denon just to be safe:
Or the back or side if there are vents. Basically just trying to pull hot air out of the unit and either circulate or get it out of the cabinet.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I use these on top of both my AVR's https://www.amazon.com/dp/B01LW0G46K/ref=sspa_dk_detail_5?psc=1&pd_rd_i=B01LW0G46K&pd_rd_w=GqaZ4&pf_rd_p=8a8f3917-7900-4ce8-ad90-adf0d53c0985&pd_rd_wg=OTAfj&pf_rd_r=K3A8KA19693YHG086V65&pd_rd_r=b2f02998-8257-11e9-b4c5-ef907af3647f
the Emo doesn't get warm at allWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
