Polk OS70 Outdoor Speakers
MrBuhl
MrBuhl Posts: 2,419
edited May 2019 in Speakers
Looking to do a quick and relatively inexpensive revamp of the patio/deck this spring... in short, these can be had from the Polk Store (fleabay) refurbed for less than a hundo. 6.5" two ways with a 1" dome. Hard to imagine you can do better for $90? Thoughts? Experience? Thanks Polkies!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
  • rooftop59
    rooftop59 Posts: 8,120
    Is it covered? I just use older indoor Polk bookies on my partially covered patio...https://forum.polkaudio.com/discussion/186702/decent-cheap-outdoor-speakers#latest
    Game Room 5.1.4:
    Bedroom 2.1
  • MrBuhl
    MrBuhl Posts: 2,419
    Sadly not enough - just under an overhang/eave, maybe 16"-20" of coverage, they need to be fairly weather resistant.
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
  • Jimbo18
    Jimbo18 Posts: 2,351
    I don't know about those, but I picked up a pair of Atrium 4's for someone. I haven't heard them but he was completely underwhelmed with them.
  • MrBuhl
    MrBuhl Posts: 2,419
    Yea, I saw a good deal on those A4's but a 4.25" MW seems kinda underwhelming for an open air back deck, hoping these will fill the bill a bit better.
    They're powered by a decent HK Receiver in the garage whose only duty is this pair of speakers, with a BT Streamer plugged into it so I can control from my phone.
    Fingers crossed, I bit the bullet, I'll keep you all posted!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
    F1nut Posts: 52,102
    As long as Alexa isn't built in they should be fine.
  • MrBuhl
    MrBuhl Posts: 2,419
    LOL thanks Jesse! I got a small BT that has really great range (surprisingly good through the wall) to connect to the receiver... no Alexa required or desired!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
