Wireworld Comparator Gizmo
verb
This very intriguing looking gizmo got me thinking. Anyone use one of these?
They even have an intellectual property patent, (US Patent 5,740,255).
https://patents.google.com/patent/US5740255A/en
Abstract
The method for comparing the sonic characteristics of two pair of audio interconnect cables includes the step of, in a first instance, switching, electrically connecting and transferring the analog electrical signals from an audio source to an amplifier driving a pair of speakers (sometimes speakers in a headphone set) via a pair of reference interconnect cables (sometimes referred to as a reference cable set). In a second instance, the method includes switching, electrically connecting and transferring the analog electrical signals from the audio source to the amplifier and speakers via a test interconnect cables set. The designation of cables as "reference" or "test" cables is not important. The steps of switching, electrically connecting, and transferring the analog signals to and from the reference cables and the test cables are conducted with substantially identical electrical losses and electrical signal distortion. One type of cable comparator may compare a test cable set to a short, direct connect, low loss electrical channel in the comparator. The interconnect cable comparator includes a switch assembly having signal input terminals, switchable cable output terminals, signal output terminals, and switchable cable input terminals. The cable comparator includes high quality RCA female ports or jacks directly coupled to the terminals of the switch assembly. The interconnect cable comparator reduces and eliminates, if possible, electrical losses and electrical signal distortion between electrical channels established through the signal input ports, the switch assembly, the four pair of interconnect cable ports and the signal output ports.
And, they have coined the phrase "cable polygraphs". Interesting.
Here's the link:
http://www.wireworldcable.com/
Abstract
Here's the link:
Calling @Clipdat !
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Seems likely it would impart some of its own sonic signature on what you are hearing making any comparison somewhat tainted.
Agreed. Let's see the inside of it.
"The interconnect cable comparator includes a switch assembly having signal input terminals, switchable cable output terminals, signal output terminals, and switchable cable input terminals. The cable comparator includes high quality RCA female ports or jacks directly coupled to the terminals of the switch assembly."
All of the things in bold can have a potential influence on the sound, however slight.
I understand what they're going for here, but bottom line is that it's something else in the signal path.
If all things in the gizmo are equal then I would find it useful in comparing cabling side by side.
Agree. Having some challenges figuring out as to how this actually works. And how to hook it up. Found this snippet which is interesting. Their very own test track disc.
12 / 17 / 02
Wireworld Inc. has released information their Cable Comparator Disc. Wireworld believes wholeheartedly in the scientific and analytical approach instead of snake oil and marketing hype. The Cable Comparator Disc CD has seventeen tracks of the same song. Fifteen of these tracks were made by feeding the analog audio signal through a selection of 1 meter interconnects. Six of the cables are Wireworld's brand new Series 5 models and the others are well-known competitors. Another track is made with a 10-meter long pair of the same type of cable that was used in a 1-meter length to make one of the other tracks. The 17th track is made with a direct connection to serve as a benchmark of comparison. The disc is claimed by Wireworld to "demonstrate objectively that most cables cause substantial amounts of audible distortion, and that Wireworld Series 5 cables effectively minimize this distortion to provide greatly improved sound quality." The Cable Comparator Disc also contains a CD-ROM section with background information on the testing, product literature, and technical discussions on the issues of cable performance. It is a promotional product and is free of charge while supplies last.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
12 / 17 / 02
The snippet you found says it all and now I know they even bothered to file their patent. I know a little about patents and how they are worded and already spent too much time reading theirs. It was total BS. All they actually claimed is if you put a switch between 4 different interconnects you can switch between them and it will add the same amount of distortion to all four. So you can compare how the interconnects sound.
What the light bulb does is anyone's guess. Not in the claimed as a working part so it is purely for looks.
The thing about patents is they don't have to have any actual utility or value. A patent just stops other people from selling what you cover for about 17 years. I was wondering why they patented something than anyone could make with a simple multi pole switch..........At least that was what I was thinking before you posted about the CD they were giving away as as a marketing tool. They can say "our product was tested using a patented method" (A BS Patented method). Purely marketing hype but I am sure some people bought their cables because of it. -
Interesting comments @delkal I agree with the patent criteria. I myself have a patent that was supposed to be released on one of our vehicles, but due to a variety of reasons (dang bean counters) never made it to production!
And, talk about marketing, I was struck by the term they coined "cable polygraphs" what?
