Subjective..question..which is "better" sounding ?
Adam Czepiel
Original sda1..6 driver ..or original sda 2..5 driver ?
* The Trouble with Doing Nothing , is that you Can't Tell if you are finished *
The 6 driver model IMHO, but SDA sounds best on the later models. They gained better insight into what they were chasing and improved tremendously with each generation. If you haven't already acquired a pair, I would look for the later SDA 1c, SDA-SRS 2.3TL or 3.1TL's...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yep SDA1a all day. I have a pair of SDA1 signatures and they responded very well to new caps and resistors.
The lower 2 drivers are dedicated to bass. -
Wound up grabbing a set of original sda1..
* The Trouble with Doing Nothing , is that you Can't Tell if you are finished * -
"Original" as in "has two nostrils"?Adam Czepiel wrote: »Wound up grabbing a set of original sda1..
Polk had a "kit" and instructions to convert them to 1A. The instructions are on this site somewhere, but the parts kit is long discontinued.
