RTI 9 replacement drivers ? where to buy
gentlejax
I just noticed one of my drivers , the one on the top , is not working. where can I buy replacements ?
Ummm Polk customer service?
I'd think that would be a good place to start. -
they are backordered so any other suggestions ?
Polk is the only source for that.Political Correctness'.........defined
President of Club Polk -
no its not. there is a place online. I pulled the bad one out and googled the part number #RD555-2 and it popped up at a place that sells the drivers...
https://reconingspeakers.com/product/polk-audio-rd5552-1-mid-woofer-for-rtia1-rtia9/ -
Gee, you could have done that back on May 15th.
Polk is still the only source though.Political Correctness'.........defined
And they buy them from polk i do believe.
Correct.Political Correctness'.........defined
gee you have been so much help, no not at all actually.. -
Well then, if you already found a place to buy the drivers, you've answered your own question .HT SYSTEM-
lsi 9's -
Says the helpless one....lolPolitical Correctness'.........defined
