Crown ps-400
A friend is inheriting a pair of SDA 2 (?A). Is the Crown common ground?
DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • FTGV
    FTGV Posts: 3,650
    According to the schematic it is. If you have a multi meter you can confirm. You should see only a fraction of an ohm across the amps negative speaker terminals.
  • jonicont
    jonicont Posts: 283
    FTGV wrote: »
    Thank you. Is this done with the amp plugged in AND turned on? Do I check at the external terminals?
    F1nut Posts: 52,406
    No, unplugged. Yes, the negative binding posts.
    Pro amps are not the best choice for home audio.
  • jonicont
    jonicont Posts: 283
    Thanks. Yeah, he’s a kid just starting out. We’ll get him there
