Psw 404
Willow
Willow Posts: 11,370
edited May 2004 in Speakers
good or not so good sub.......?? I have 400$cad to spend on a possible sub I don't want Ebay, or order online.....what would peeps recommend...should I go the velodyne way ? the ch8 or the vx10bv??
  • Pauly
    Pauly Posts: 4,519
    edited May 2004
    actually i used to own the 404 (topped off with a 350). IMO it is a great sub for music and some HT. has some bump but not the deeeep bass some people look for. What size room you in? Do you like ALOT of DEEP bass? What will you primarly be using it for HT or Music, both? what fronts, center surr etc do you have. Need to size up what you have and go from there.
    Spaz
    Life without music would♭
  • Willow
    edited May 2004
    right now rti4 csi3 r50, room 14wx20Lx9 and its about 50/50 music and HT
  • organ
    organ Posts: 4,969
    edited May 2004
    You're in Canada. Check out Paradigm, Energy and PSB. We get great deals on them here. Better than Polk when it comes to more bang for your dollar.
    Maurice
  • glemay
    glemay Posts: 574
    edited May 2004
    I agree with Organ, Paradigm is the way to go if your Canadian. I've got a PW-2200 in my room and it is just amazing. The room is a little smaller than yours but not by much. Even the PW-2100 sounded very good for the money.
    Main System:
    Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
    Second System:
    Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
  • Willow
    edited May 2004
    thanks I will check it out this weekend
