SDA Surprise!
dkg999
dkg999 Posts: 5,647
edited May 2004 in Speakers
Has anyone else found that the SDA's are not always the best option for HT front mains? I have a set of SRS's at my house and a set of SDA 2's at my apt. that are part of an HT set up. I thought the SDA 2's were great in the HT setup, until I found a set of slightly used RTi70's at a garage sale for an incredible price and brought them home. I know the SDA's are finicky on placement, but I have had both the SDA 2's and the SRS's since they were new, and know about how to place them in a room. When I switched back and forth from the RTi70's to the SDA 2's, the SDA's always seemed overpowering, while the RTi70's seem to blend in and not really stand out, but compliment the rest of the system. The rest of the system is:
Yamaha HTR5660 - driving the all speakers except the SDA's
Yamaha AX-900U - used to power the SDA 2's
Polk RTi70
Polk CSi40 - front center
Polk RTi38 - rear surround
Polk CSi30 - rear surround
When listening to music, there is no comparison, the SDA's blow the RTi70's away!
DKG999
  • amulford
    amulford Posts: 5,020
    edited May 2004
    They weren't really designed for HT, were they? (not trying to be a smart ****)
    The 70's were designed to go with the other speakers in your set up, timbre matched. I bet it does sound good!
    F1nut Posts: 52,406
    edited May 2004
    Ed Zachary
  • dkg999
    dkg999 Posts: 5,647
    edited May 2004
    amulford - You make a good point! I just never really realized how much difference there would be. I read all the posts discussing timbre matching, and just never realized the importance of it. Prior to taking the plunge into full HT, I had just ran the audio from the TV, VCR, or DVD into my amps (Yamaha C2/M2x2 for the SRS's and the Yamaha AX900U for the SDA's) into my speakers, and it sounded pretty good, but nothing like the whole surround sound experience. Now I keep the SRS's at my place on my farm in IA, and I have the SDA's and the HT at my apt. in IL. Nice to be able to crank up the SRS's with a good CD and not have any neighbors complain!
    The sad thing is I never would have discovered the difference if it weren't for a noticing a pair of tower speakers at a garage sale that turned out to be the RTi70's at the bargain price of $50 for the pair. Offered them $35 and they took it! Only a couple of minor scratches on the back of one speaker, the other has a scratch on the base.
    DKG999
  • Larry Chanin
    Larry Chanin Posts: 601
    edited May 2004
    I have heard others on this forum complain that SDA don't always match up with other speakers, particularly the center channel, as much as they would like. I suppose those with the skills to hear these subtle differences that is the burden they have to bear.
    Perhaps because I don't have a trained ear, I have not noticed any problems between my SDA-1Cs and my CS400is and f/x500is.
    However, even conceding this timbre matching point, don't you think the SDAs have superior imaging when compared to conventional speakers, including the RTs? It never ceases to amaze me on those occasions when I hear sounds projected outside the boundaries of my home theater's walls. Can the RTs produce sounds that seem to come from a point beyond the speaker spacing?
    Although its true that the original SDAs were not designed for home theater, wouldn't this imaging characteristic make them a natural for home theater? How about the mother of all SDAs, the SRTs, didn't Matt Polk design them for home theater?
    I'm not doubting your observations regarding matching, I'm just suggesting that the SDAs have other characteristic that might make them good performers in a home theater.
    Larry
  • dkg999
    dkg999 Posts: 5,647
    edited May 2004
    Larry - those were my thoughts exactly prior to adding the RTi70's! Because I them set up so I can easily switch between the SDA's and the RT's I have been doing additional comparisons. All your points about the SDA's are valid. Their soundstage and imaging are awesome. What seems to happen is that they overpower everything else. Maybe it's because I have a smaller room (16x18 ft.)? When using the SDA's they seem to take over and you don't get as much of a balanced surround sound effect. With the RT's I get much more presence from my front and rear center channels and my rear surrounds, although I do give up some bass. The SDA bass combined with my sub-woofer is pretty awesome.
    Now the really good news. Using both the RT's and the SDA's, with the volume on the SDA's turned way down, look out! The SDA's, even though barely audible, seem to fill out the soundstage and add a huge amount of presence, while not being overpowering. Probably overkill on the chick flicks, but for Master & Commander, someone bring the tools because I'm sure the cannon ball actually went thru my living room!
    DKG999
  • Larry Chanin
    edited May 2004
    I'm curious how are you balancing your speaker levels? Are you going by ear, or are you using a sound pressure meter to calibrate your levels?
    Larry
  • danger boy
    danger boy Posts: 15,722
    edited May 2004
    the RTi70/RT800i have been a fave in here for years. now you know why. ;) you just can't go wrong with using RTi70's for fronts. their mid range is better than alot of others out there
    PolkFest 2012, who's going>?
  • dkg999
    dkg999 Posts: 5,647
    edited May 2004
    Larry - I suppose you're going to tell me I need to get more scientific! I balance them by ear.
    DKG999
  • Larry Chanin
    edited May 2004
    Hi dkg,
    No doubt there are a few folks whose ears are sensitive enough and trained enough to balance the SPL levels of their speakers without scientific aids. I'm certainly not one of them. ;)
    Ultimately the listening experience is all about how YOUR ears perceive the sound. So even if you were to use an SPL meter your ears still have the final say in what you consider enjoyable.
    However, as I understand it you need a 3dB or so change in SPL levels for the average person to even perceive any difference whatsoever. Therefore, although differences in timbre matching might contribute to what you are hearing, without first knowing conclusively that your speaker levels are balanced, its hard to reach any firm conclusions of the overall suitability of one speaker over the other for a home theater application.
    Larry
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    I'm using RT3000P's as the fronts in my HT system. However, after leaving the Parasound P/PS 1500 (AV Processor/Preamp.) the signal goes through a Caver C-9. (Sonic Hologram Generator) This way I can switch back and forth between SDA or not. I like it both ways but leave the system set for SDA which I prefer.
    Different strokes kinda thing I guess.
  • George Grand
    George Grand Posts: 12,256
    edited May 2004
    At first I was pleasantly surprised to see Larry Chanin on this thread. Now I'm double surprised. Welcome back Bob, it's been awhile.
    George Grand (of the Jersey Grands)
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    Hi my friend. It has been a while. Perhaps too long...
    At any rate, I think that's why I'm a bit suprised myself but I had to check in and see what was up. It's great to see all the familiar names here. I really should check in more often then I have.
    BTW: Be on the lookout for something headed your way. I'll let you know more...
  • Larry Chanin
    edited May 2004
    Hi George,
    It's nice being back and I appreciate the welcome.
    Regards,
    Larry
  • George Grand
    edited May 2004
    It really is great to see old heads back and posting.
  • madmax
    madmax Posts: 12,434
    edited May 2004
    Wow! I'm in a time warp here. It is 1 AM and all of a sudden it feels like the mid 1990's again on the site. Nice to see all the names!
    madmax
    Vinyl, the final frontier...
  • Tour2ma
    Tour2ma Posts: 10,177
    edited May 2004
    dkg999,
    SDA's offer some special HT calibration challenges owed to the fact that during the main L or R ch test tone(s), the SDA drivers in the opposite speaker are involved.
    Once dialed in though, as Larry indicated, the blending with the surround ch's is better than standard 2 ch mains... IMO.
    More later,
    Tour...
    Vox Copuli
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    Good to see you here Chuck!
    Time warp? I'd say, sure looks like it.
    Hi Larry!
    You guys still in SDA site?
    I know, I know, go look through the members list...
    VR3 Posts: 29,762
    edited May 2004
    SDA speakers + Home Theatre + SPL meter = FRICKIN AWESOME
    The side soundstage, and the transition from left to center to right is outstanding. There just isnt a comparison.
  • Larry Chanin
    edited May 2004
    Hi Larry!
    Hi Bob,
    Yes, your SDA site still has the best collection of SDA information available anywhere. How's your brother doing?
    Larry
  • BobMcG
    BobMcG Posts: 1,585
    edited May 2004
    It's good to see there are still a lot of members in the club (80). I guess I don't have to tell you I haven't be there much in the last couple of years. I answered a few qustions but sent personal emails.
    Mike is fine, thanks for asking. He's been keeping very busy building up the computer business (BlueLine Technologies) we started close to two years ago. It's doing fine and growing all the time. I don't think Mike has been around the audio scene much in a while either.
