Outdoor speaker mounting - distance and height
njw
njw Posts: 1
Hi. I have 2 pairs of atrium6's on the way. My application is an 800 square foot outdoor covered deck. The deck runs 36 feet along the house, and 22 feet off the house into yard. The first 14 feet (14x36) are covered with 11 foot hight ceiling.
My plan is horizontal mount on the house. I have no clue what I am doing - lots of internet research. How does this sound? Set a speaker in 3 feet from each edge and have a speaker every 10 feet. I was going to put them at 10 feet high. Running 14 gauge wire to a sonos amp. All of this is brand new to me. I was planning to alternate Left and Right and face the tweeters in on each pair.
Thanks.
Neil.
    Clipdat Posts: 13,101
    Got a drawing? It's hard for me to visualize what you're planning.
  • recoveryone
    recoveryone Posts: 929
    placement outdoors will always be a mystery as so many elements come into play.
    1. seating postions
    2. open spaces (lack of walls)
    3. soild cover (roof/patio cover)
    4. Purpose (Goals, what are you trying to achive)
    Outdoor/patio settings are mainly for background music, no sweet spot for real/critical listening. Bass is what suffers the most, due to the openness of space.
  • DaveHo
    DaveHo Posts: 3,583
    Based on your description, you've basically created 2 zones on the deck, covered & uncovered. You could mount the speakers on the house and focus each pair to the zone it's covering. Another alternative would be to mount them back to back on the structure that's separating the covered from uncovered areas so that again, one pair is focused on each area.
    14 awg wire may be a bit small depending on the length of the run back to the amp.
