Help with replacing RTi A3 woofer
I trying to figure out which woofer is the replacement part for these speakers. It looks like the part may be discontinued. Thanks.
    F1nut Posts: 52,012
    Good luck, you'll need it.
  • I found a cosmetically damaged pair online that I have on the way to strip and use for parts
