Y is Sony So Bad? part 2
SPEAKER7
SPEAKER7 Posts: 355
edited January 2002 in Technical/Setup
Hi,
Just wondering if any Polk owners has or had a Sony WEGA
400/450 xbr 36"? I'm almost ready to pick one up next month after saving for the past 10yrs to replace my 27" Sony trinitron that I purchased back in 1990. How is the reliability factor.....the Sony that I currently own is still working fine and was made in Japan but I believe the new models are assembled in Mexico.
Quality control?
dc.:confused:
Post edited by SPEAKER7 on
  • wangotango68
    wangotango68 Posts: 1,056
    edited January 2002
    ask micah were the polk speakers are made? you like them don't ya?
    scott:cool:
  • presidan
    presidan Posts: 116
    edited January 2002
    Well, i bought a HDTV 32" Panasonic TAU TV back in september. I can tell you that i made a lot of research to find what i was looking for.
    The TAU (forget about the GAOO's) outperforms the Trinitron XBR is every category. Sure, it might be a little more expensive but it is worth it. I'M not saying that the XBR isnt good, they both look great but you'll get more out of the TAU. But you'll be able to get a good deal, get the stand with it. This sucker weights 160 lbs !
    RT2000i
    F/X1000
    CS400i
    DENON AVR-3802
    PIONEER PDP 4360-HD 43"
  • ntculenuff
    ntculenuff Posts: 1,146
    edited January 2002
    i own the wega 36xbr200 and if it came down to a new tube tv i would go with another xbr I LOVE MY WEGA.
    i know it is the older model than you asked about but one thing sony doea do right is tv's
    my cents
    Speakers:
    Definitive BP7001sc mains
    Definitive C/L/R 3000 center
    Polk RT800i's rears
    Definitive supercube I Sub
    Audio:
    Onkyo TX-NR3010
    Emotiva XPA five Gen 3
    OPPO BDP-103 CD, SACD, DVD-A
    Video:
    Panasonic TC-P65ZT60
    OPPO BDP-103 Bluray
    Directv x's 2
  • trubluluc
    trubluluc Posts: 2,067
    edited January 2002
    Had a 36" WEGA, very good tv.
    I traded up to a 55"mitsubishi rear projection, because I wanted a widescreen television.
    No complaints towards the Sony, very clean/clear picture, excepting it's massive weight. 200+ lbs.
    -luc
  • SPEAKER7
    SPEAKER7 Posts: 355
    edited January 2002
    thanks guys for your reviews on the Sony Wega!
    I hope to get it in about 4wks..... and I can finally watch my DVD's
    in a slighly bigger picture....from 27" to 36".
    dc.:)
