What is a good Dell laptop
BlueFox
BlueFox Posts: 15,250
I retire the end of April, and will have to turn in my Dell laptop. I haven’t turned on my home computer in years, and will junk it for a new Dell laptop. However, they have so many different models. LOL.
Does anyone have a suggestion for a good laptop that I can take to the grave. :)
  • rpf65
    rpf65 Posts: 2,127
    Think a friend, who works at Dell, owns a Lenovo.
  • daddyjt
    daddyjt Posts: 3,186
    I was a Dell guy for years, then I had a Lenovo for work about 10 years ago. That thing was built like a tank - I carted it everywhere, dropped it, traveled with it and basically abused the heII out of it. The thing impressed me so much, I bought them for my kids, then got one for my personal use. They are not sleek or sexy, but they have it where it counts. Great battery life to boot.
    Just my .02
    ― Aleksandr Solzhenitsyn
    Clipdat Posts: 13,100
    edited April 2019
    We use Lenovo laptops at my office and I work extensively with them. I would hesitate to recommend them.
    Personally, I would rather go for a nicely appointed Dell Latitude 7490.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,919
    For home-use, one of these two: Dell Latitude or Dell XPS.
    I recommend a Dell Latitude for top of the line quality with whatever options you require.
    If I wanted a more modern "Apple looking" then the Dell XPS. Thinner, lighter, etc.
    __________________________________________________________________
    If I wanted the very best from Dell and money is no object, then the Dell Precision Laptop (usually called mobile workstation) has no equals. I have had an older Precision desktop for years purchased from Dell outlet that is more like a battleship. It can be dropped with no damage. The build quality is amazing.
    I would buy direct from Dell in order to choose your exact choice. Places like Best Buy usually compromise to reach a desired price. If anything happens to your Dell under warranty, service is performed at your house.
    One other place to purchase a Dell is Costco. Costco builds out their offerings with the most memory, etc and extends the warranty. You can look at Costco online if there is not one nearby.
    I am retired but my work, the big soda company in Atlanta, was Dell for Windows.
    Harry
    Harry / Marietta GA
    xschop Posts: 5,653
    Preferably one without all the bloatware.
  • aiconn
    aiconn Posts: 277
    We too use Lenovo at work. I have no problem with them as long as you stick with the Thinkpad line. I also bought my son a new laptop for college. Since he's an engineering major I bought him this:
    https://www.dell.com/en-us/shop/dell-gaming-laptops-and-notebooks/new-dell-g5-15-gaming/spd/g-series-15-5590-laptop/gnvca5ch1507h.
    My wife has this for daily use:
    https://www.dell.com/en-us/shop/dell-laptops/inspiron-13-7000-2-in-1/spd/inspiron-13-7375-2-in-1-laptop/dncwdamd1005h
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
    msg Posts: 10,529
    edited April 2019
    I agree with the above - Latitude 5000 or 7000 series, XPS. I have been pleasantly surprised with some of the newer Inspirons. They use to feel a bit creaky and flexy. Lenovo Thinkpad is also nice, agreed. Here are a few more notes to consider when trying to narrow down your choice.
    WHAT SIZE DISPLAY WOULD YOU LIKE?
    • 13" is nice for portability and travel, but small. May be difficult to use at 1920x1080
    • 15" is comfortable; best all 'rounder.
    • 17" is handy for multi-tasking, graphics, or if you prefer a large display for extra cushy use of high resolution, like 1920x1080 or higher. At this level the machines are heaviest in comparative weight.
    GLOSSY OR MATTE?
    Consider whether you want glossy or matte display. I prefer matte. Easier on the eyes, greatly reduced reflections
    WHICH SCREEN RESOLUTION ARE YOU MOST COMFORTABLE USING?
    • 1920x1080 is fairly common now. Can be a little tight on smaller laptops
    • 1600x900 I thought was the best middle ground if full HD wasn't necessary, but rare native display now.
    • 1366x768 is comfortable on almost any screen, but limited "real estate", may seem too short, depending on use.
    WHAT KIND OF BATTERY LIFE ARE YOU AFTER?
    Those Dell Latitudes noted by the guys in the posts above have stupendous battery life.
    IS WEIGHT A CONSIDERATION?
    Travel with it, have it on your lap? Those 7000 series Latitudes and some XPS machines are made to be thin and light.
    PERFORMANCE
    • Video - As long as you're not gaming or designing, the onboard Intel display adapter should be fine.
    • Disk - Make sure you're getting something with a solid state disk (SSD). I think most at the Latitude, XPS and Lenovo levels have moved from the 2.5" to M.2/NVMe/PCIe, which are even faster than earlier SSDs. Depending on what you're doing, capacities range from 128GB, 256GB, 512GB, and 1TB, typically. 512GB is the sweet spot here, 256GB is still usable, but you may run out of space if storing photos, video or music locally.
    • Processor - Intel Core i5 is the sweet spot for performance and battery life
    • Memory - 8GB-16GB is about standard these days. Shoot for 16GB, but 12GB would be acceptable. I'd even go 8GB and upgrade later if it hits all your other points.
    CONNECTIVITY
    • Need Ethernet?
    • A bunch of USB ports?
    Laptops these days are coming with fewer ports. USB-C is becoming the standard. On some machines, I've seen two USB-C ports and a single USB 3.0 port. Good news is that there are adapters and convenient small, bus-powered hubs you can use to convert and add additional USB ports and ethernet to those machines that don't ship with them, so don't let that necessarily deter you from a machine that checks all the boxes otherwise.
    One I use as a second around the office was a spare that I adopted. It's a modest 15" Latitude E5570 Core i5 dual core with 8GB RAM and 256GB disk. FHD 1920x1080 matte display with the integrated Intel video adapter. Works great for most everything. Fast. The only thing I don't like about the Latitudes is the finish. It picks up fingerprints easily. Sometimes I find the full HD display a little small if I'm using it on my lap and not at a desk, but it's not bad.
    Then, there's always the Macbook Pro ;)
    Post edited by msg on
    msg Posts: 10,529
    xschop wrote: »
    Uninstall that jank, or quit buying E-Machines! :D
    Anyone remember these?
    mhardy6647 Posts: 35,359
    edited April 2019
    Go with a business-class Lenovo. Way more robust machines IMO.
    Used to love Dell, but the quality slipped steadily starting over a decade ago (again IMO).
    I gave up on Dell after buying one (ca. 2011) that failed 10 days out of warranty.
    I now buy used Lenovos from "my IT guy" (a small one-man shop who works out of our old town of Harvard, MA). I use one for the class I teach in Boston (an elderly T430) and another for my LLC/home use (a somewhat more modern T440). These machines are unsexy, but they're fast and rugged.
    msg Posts: 10,529
    Good note, Doc, on the business class versus home machines. It's a bonus if they live beyond warranty, and many do.
    Business class machines offer performance and build quality over home grade, which seem to be generally made and configured to be replaced after 2yrs. Also often minimally specced, making for slow, frustrating performance.
    Business class computers offer some refinements. Better components, nicer keyboards, etc., and, as you said, more rugged design. Metal parts. Display hinges, for example. Seen many a laptop ruined simply due to poor hinge design found on some of the cheaper machines.
    Nothing wrong with either choice, just depends on what kind of user you are, and what kind of life, performance, and feel you want out of a computer.
    I am sooo tired of hinge issues on cheap laptops. :/
    Mrs. H's (cheap) Lenovo* currently has one hinge that's hanging by a thread (almost literally).
    ______________
    * Now, mind you, this cheap Lenovo is of essentially the same class (200 dolla, plastic lappie) as the Dell I mentioned previously -- that said, the Lenovo still works fine, having outlasted the Dell by nigh on five years. The Lenovo's hinge issue is quite recent.
  • aprazer402
    aprazer402 Posts: 3,449
    Just a quick aside: :)
    Two hot air balloonists who were blown off course and found themselves near a building with some people on the roof. One balloonist shouted out; "Where are we?" and the rooftoppers yelled back "You're in the gondola of a hot air balloon!" The balloonist turned to the passenger and said "Oh. We're in Redmond, WA and that's Microsoft HQ." His companion asked "How do you know that?" "Well," he answered "like their tech support, the information they provided was technically accurate but practically irrelevant".
  • maximillian
    maximillian Posts: 2,149
    No 4k video love? Personally love mine. Issue is that if you go with a dual monitor and use the laptop monitor then you really need a 4K external monitor as well. It's a pain dragging back and forth between the two if they are not the same resolution.
  • dromunds
    dromunds Posts: 10,159
    I’ve been using a Lenovo Thinkpad laptop and it’s pretty crappy. I also have a Dell XPS which I really like, and Dell’s customer service has been very good. I have a MacBook Air that I also like, but sometimes Apple drives me crazy.
  • Old Thread I see ! In the last year I went with the Dell Precision 7730 and no complaints!
  • machone
    machone Posts: 1,572
    Yes, Dell Precision is very good. That is what I run as a mobile desktop for solid modeling.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • kevhed72
    kevhed72 Posts: 5,187
    Get a Mac Book. I never owned one but that's the ticket!
  • Emlyn
    Emlyn Posts: 4,864
    Considered a desktop computer with a wireless keyboard and mouse instead? In my experience they last a whole lot longer than a laptop and can be upgraded easily too.
    Easily hooked up to a big screen TV too.
    I haven't had a personal laptop for years now. When I'm mobile I just use an iPad or iPhone. For work I'm now on my third high spec HP laptop in two years. The batteries in those things swell up and split the case open. I think some Dells have the same problem.
    pitdogg2 Posts: 27,540
    Battery problems seem to affect most of them now.
  • BlueFox
    I ended up with an Inspiron 15 3000 series, model 3581. So far it has been fine, although I primarily only use it on Friday to download new music from HDTracks. Other than that I use my iPad for browsing.
  • gmcman
    gmcman Posts: 1,864
    dromunds wrote: »
    Best Buy has a decent deal on a Lenovo Legion 5 right now, until Friday I believe. Been looking for a mid-range laptop for my son but I have some criteria, and this meets most of it. Not a bad deal for a 1660 Ti laptop with NvME storage. The Lenovo is definitely well made.
    https://www.bestbuy.com/site/lenovo-legion-5-15-gaming-laptop-intel-core-i7-8gb-memory-nvidia-geforce-gtx-1660-ti-512gb-ssd-phantom-black/6398969.p?skuId=6398969
  • gyosa
    gyosa Posts: 770
    edited December 2020
    Does it have to be dell ?
    The only laptop you will be able to take to the grave is a MacBook ....
    I have had a mid-2012 MacBook Pro bought new 2013 or so .
    Works flawlessly- always has......
    Recently installed a 1tb ssd , 16gb ram - up from 4 , and a new battery.
    Easy peazy.
    It’s a sweet machine now ....it flys !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • gyosa
    gyosa Posts: 770
    yeah ,
    I noticed after I posted that it was an old thread .. LOL
    yes , the new MacBooks with the M1 chips are a game changer I believe ... I'd get one now BUT , I want 32gb ram so I know its future proof, and the current M1 can only support 16gb.... so , will wait....
    this MacBook is a hand me down from my 17 yr old son who realized he wanted a ALIENWARE laptop for gaming .... I guess Macs suck for gaming....
    I've been using this Mac for a few years now and will never go back to a pc - no matter the price difference ... Macs will last forever , pc's not so much - lucky to get a few years before the OS self destructs or gets corrupted...
    I got the battery from OWC - after much , much research I determined that it was worth a few extra bucks to get one from them as most of the amazon batteries are crap after a few months use.
    memory was from Crucial.
    SSD is from Samsung.
    a bit less than $300 for all ... cheaper than a new MacBook , and it'll keep its own now...
    runs so awesome now , I really don't foresee the need to replace for a few years ...
    of course , I did a clean , no backup , install of Mac Catalina OS on the new SSD ....soooooo easy - unlike a PC - couple keystrokes , and its done....
    the RAM made a big difference , obviously... from 4 to 16 ....
    but the SSD made a unbelievable difference ....
    did I say unbelievable ?
    bk
  • gyosa
    gyosa Posts: 770
    Battery from OWC
    SSD from Samsung
    Ram from Crucial
    bk
    VR3 Posts: 29,626
    Im rocking a sony vaio laptop from 2010, runs 3 external monitors and does what i need.
    I7 quad core, was 1400 back in the day! Even has my name engraved in it from the manufacture
    I installed a ssd, maxed out the ram and had to change the keyboard due to dumping 32 ounces of coca cola on it...
    Still ticking! Knock on wood!
