PCB Repair Supplies
jdjohn
I just received my order from the guys at Circuit Medic http://www.circuitmedic.com/index.html , and IMO they are a great source for PCB repair supplies.
Here is my problem:
Solder pad came off (red circle)
My order from Circuit Medic aka Circuit Rework:
Thermal resistant tape, Circuit frame sample form, Heat-activated epoxy film
Plan is to first put a small triangular piece of bonding film under the trace remnant, put a small piece of high-temp tape on top for the heating/adhesion process, use soldering iron for adhesion.
Next, cut appropriately-shaped piece from circuit frame film to add as new solder pad. The bottom of the film has a heat-activate epoxy, so again use the high-temp tape as a heat buffer for sticking the pad in place.
Circuit Medic has a series of how-to videos which show the process in detail...very interesting and informative.
Here is my problem:
Nice
