Brass Spikes - Any Experience With Adona?
Long story short, I am making my own platforms/stands for the JMLab Electra I just purchased, and have been looking at this website. Seems like a very solid deal if you'll excuse the pun.
Would be using the "large brass" or "extended" - under some solid maple bases - the JMLab's currently are not spiked and I'm on carpet. I definitely hear a difference on the Lsim 705's and my 1c's so I anticipate a similar improvement with this change as well.
http://www.adonacorporation.com/tweaks.html
Anyone have any experience with them? Many thanks!
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Sony S9000ES CD/DVD/SACD
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
    EndersShadow Posts: 17,741
  • aprazer402
    aprazer402 Posts: 3,449
    This is the only Adona I'm aware of with brass cones.
  • kharp1
    kharp1 Posts: 3,453
    Adona stuff is generally pricey, but, well made.
    F1nut Posts: 52,146
    Ed, the Multi-Element Cones are exclusive to Adona. Great spikes and well worth the money. The others are variations of the Dayton spikes, which aren't half bad.
  • MrBuhl
    MrBuhl Posts: 2,419
    edited April 2019
    @aprazer402 LMAO that was a good one! I don't think she's quite as sexy though!
    @F1nut @kharp1 thanks gents! I will proceed then, pics will be forthcoming!
    Polk SDA1c modded
    SACD Marantz DV8300
    Yamaha YP-D6
    Pho-700 Phono Pre
