Have a couple extra 6.5" drivers; how is the best way to store them?
I have a couple of extra 6.5" Polk drivers; how is the best way to store them?
Thanks, Lou
Marantz PM8004
Marantz SA8004
Marantz NA 6004
Polk SDA 2
Polk SDA 2A
Kef C95
  • JPete
    JPete Posts: 298
    Mine are in boxes in a closet.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • FestYboy
    FestYboy Posts: 3,861
    Voice coil in a vertical orientation.
    pitdogg2 Posts: 27,411
    I zip tie mine face to face and store in a box.
    VR3 Posts: 29,565
    In the oven so the coils won't freeze up
    But yes, you want the cone parallel to the surface, it off the way of dust
  • delkal
    delkal Posts: 764
    edited March 2019
    If you have 2 drivers find some 1/2-3/4 inch long screw spacers (or cut your own out of some tube). Screw both speakers together with some small bolts with the 4 spacers in between.
    The spacers keep the cones from rubbing together and will protect it better. Its not fun unpacking speakers and seeing the dust cap crunched in.
    F1nut Posts: 52,045
    FestYboy wrote: »
    Why?
  • FestYboy
    FestYboy wrote: »
    Why?
    Long term storage can cause spider/surround sag. With coil in vertical position, spider and surround is evenly pulled on throughout the circumference. If coil is in horizontal position, there is potential for the spider/surround to droop or twist and therefore allow the coil to contact the pole and rub once put back in use. Granted, spinning the speaker 180 will typically resolve that once installed.
    F1nut Posts: 52,045
    Arty my man, you have vertical and horizontal reversed.
  • FestYboy
    I suppose it's a matter of perspective...
    F1nut Posts: 52,045
    Ok, let's put it this way. The drivers should be stored in the horizontal position.
  • BlueFox
    BlueFox Posts: 15,250
    edited March 2019
    With the magnet facing up, and six months later have the magnet facing down.
  • FestYboy
    edited March 2019
    To me, that sounds like they are in the same position as when mounted in the enclosure. The cone moves in a horizontal* direction.
    Edit: * when mounted normally.
    Post edited by FestYboy on
    F1nut Posts: 52,045
    edited March 2019
    The drivers are mounted in the vertical position. When a driver is sitting on its magnet it is in the horizontal position.
    The driver moves in and out.
  • FestYboy
    We're getting into semantics... We both agree on the orientation of said driver regardless of the term used. Yes?
  • BlueFox
    LOL. This is the Internet. You are either right or wrong. :)
    nooshinjohn Posts: 26,016
    edited March 2019
    BlueFox wrote: »
    So you turn them every six months?
    F1nut Posts: 52,045
    FestYboy wrote: »
    Arty, I say this respectfully, it's not semantics. By saying a mounted driver is horizontal when in reality it is vertical is bound to cause someone confusion. Therefore, I think it is imperative to use the proper term. B)
    Viking64 Posts: 7,648
    One time I saw an accident where a car flipped over. The driver had been thrown from the car and he was horizontal in the middle of the road.
  • ptrooper
    ptrooper Posts: 501
    edited March 2019
    I believe Its mind over matter ,if you don't mind it don't matter, when made they should be held firmly in their correct position unless previously damaged or some kind of external force pushing them off centre and lets not forget the way they are mouted in their speaker enclosures for their entire life . I would be inclined to lay them on their back ie magnet down after glueing them !
  • FestYboy
    Based on driver motion....
    One doesn't jump horizontally, nor run vertically unless the plane of reference is perpendicular to the observer (i.e. running up a wall).
    Add on Atmos speakers (ones placed on top of the existing L & R mains) are faced vertically in accordance to their driver motion and desired sound projection. B)
    Semantics... :*
    I can see this debate potentially having the same outcome of the great "SDA effect" argument ;)
    Anywho: place the driver on a flat (horizontal) surface on it's magnet, or on it's cone. If on it's cone, use a spacer so that the surround doesn't contact the surface.
  • delkal
    delkal Posts: 764
    Now I am confused.........Do you store the speakers the same way as they are mounted in the speakers?
    If not. Should you place speakers on their sides for long term storage.
  • FestYboy
    delkal wrote: »
    90° from normal orientation. Cone should face the floor or ceiling
  • lawdogg
    lawdogg Posts: 469
    I would store them vertically.
    <3 my 3.1TLs
    I will fix your shifted magnets for free. :)
  • aprazer402
    aprazer402 Posts: 3,421
    Viking64 wrote: »
    I tried that with Milk-Bones once. When I came home, I was not happy.
