Boy was that unexpected.
Watching a horror movie and my amp blew a fuse. Sounded like a handgun. That got the kids and wife worked up. Went up, turned off the power and unplugged.
This amp is a B&k ref 200.5. I poked my head around it looked like the inside fuse is blown. Smell like smoke. Smoke also bellow out after the kapuut.
Looked around and notice 1 of my speaker was put of place. Wife said she moved the speaker. I'm guessing speaker wire came into contact somehow. Luckily I have an extra 200.2 amd now were watching movie in 2.channel as I unplugged the rear 7250 also for safety measure.
I'm praying its as simple as putting in a new fuse . Anybody ever had this happen?
Epson 3020 projector. Da Lite screen. Oppo 103. Yamaha CXA5000. B&K 7250ii. HSU VTF2. Def Tech Supercube 4000. Polk Rtia9 CsiA6 FxiA6. Monster hts 2600. Home theater.
Bedroom consist of NHT model 2 powered by Parasound hca1200ii coming from my computer.
Stuff laying around. Too much to list but don't want to sell either.
    F1nut Posts: 51,886
    How are the speaker cables connected?
  • F1nut wrote: »
    Connected via banana plug. Based on initial assessment was that a rail fuse blew. There was still sound but in the rush of turning it off and unplugging it I didn't remember to make a mental note of which speaker the sound was playing but there was still sound being emitted.
  • kharp1
    kharp1 Posts: 3,453
    edited March 2019
    Had that happen years ago on the same amp. Using some screw down bananas and one vibrated loose and shorted. Replaced the fuse, but, that didn't do the trick. Think that amp is still tore down on the bench.
  • kharp1 wrote: »
    Man. I don't even have a bench it cant sit on lol. I'm going to try and replace the fuse tomorrow and see what happen. If it doesnt work I'll either find a repair shop or use what channel is still available.
    nooshinjohn Posts: 25,955
    edited March 2019
    I would not waste another good fuse. Something else is radically wrong inside that amp, and trying to make it work without going through it first will damage something else and make matters worse.
    If you decide to ignore my advice, please take video of the fireworks and post it here.
    Post edited by nooshinjohn on
    F1nut Posts: 51,886
    Hmmmm.......my MIT banana plugs are stuck in so tight it takes serious effort to pull one out. If one of your banana plugs actually pulled out you might consider upgrading them.
  • I would not waste another good fuse. Something else is radically wrong inside that amp, and trying to make it work without going through it first will damage something else and make matters worse.
    Advice taken. Ill keep you guys posted once I have the time to take off the lid and dig around in there.
  • kharp1
    kharp1 Posts: 3,453
    edited March 2019
    kharp1 wrote: »
    Been thinking about putting it back together and listing it as a 4 channel amp but selling it at a 2 channel price. That would be like half off.
  • boston1450
    boston1450 Posts: 7,758
    Hopefully its a easy fix. Musta startled everyone. Might be a good time to upgrade the wife too :) Joke
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    EndersShadow Posts: 17,713
    kharp1 wrote: »
    kharp1 wrote: »
    Talk to me goose.....
  • DaveHo
    DaveHo Posts: 3,582
    Fuses don't typically make a loud noise and emit enough smoke to notice when they blow. The gunshot noise reminds me more of a cap going up in flames. I agree with the others, have it looked at before using again. I don't think it's a simple fuse replacement.
    DaveHo wrote: »
    I might agree with this. The very least you should pop the top and see what you can see before trying to operate it again.
