Need help finding solution for older receiver
EndersShadow
EndersShadow Posts: 17,741
edited March 2019 in DIY, Mods & Tweaks
My old receiver doesn’t have a way to connect decent speaker wire. Given its age that’s expected.
I was hoping someone might have a solution that would let me use banana plugs without having to hack into it and replace what’s there.
Here is what we are working with...
It’s really setup to use bare wire, and likely 16 gauge or higher.... I’m hoping to use lower gauge (have some lying around that is 10 I think) and more importantly bananas or decent spades, neither of which this really will accept
    VR3 Posts: 29,630
    I could be wrong, but given the screws around the perimeter of that plate... Can you remove it? May be easy to just installing binding posts
    pitdogg2 Posts: 27,563
    FR 4 or G10 is your friend
    DSkip wrote: »
    I saw those in Zingo's thread.... wasnt sure if they would work for me or not, but I will do some more digging there...
    VR3 wrote: »
    Possibly... I will see about that later tonight..... I'm just OCD about trying to keep it as original as possible. If I can make a "new" plate so I still have the original I may just do that....
    I'm wanting to keep the A/B if possible because I may end up running two sets in there at some point...
    mhardy6647 Posts: 35,377
    crimp-on spade lugs ought to work just fine.
    Those ol' Sherwoods were deceptively good sounding receivers with great FM sections in 'em.
    Got a few of 'em (yes, even the soiled state ones) here.
    VR3 Posts: 29,630
    The layout and size looks like it would respond well to a binding post. But I also understand your ocd, so carry on!
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,928
    edited March 2019
    verb wrote: »
    So I found these little guys. Screw right into the terminal block, with a banana receptacle at the other.
    Look at this solution that Verb found for his McIntosh amp. I have two vintage Infinity servo subs with terminal blocks, and I plan to try these. I purchased those from Amazon but don't like them because each one tends to turn and I am afraid to tighten down too much. This is the thread and on page 5.
    https://forum.polkaudio.com/discussion/184704/a-mcintosh-in-verbs-house/p5
    Post edited by BlueBirdMusic on
    Harry / Marietta GA
  • oldrocker
    oldrocker Posts: 2,590
    verb wrote: »
    That's pretty cool. One will have to determine empirically whether the studs on those are strong enough to support the garden hoses all y'all use for speaker wire, though B)
    On the plus side, AFAIK, "Pomona" still = "good stuff".
    Doc, in this case the wire will be going ON the wall, and likely physically attached to it with some of these doohickeys...
    So I'm not worried about tension, however I may just make a new backplate as that seems the easiest way to go.....
    Waiting for warmer weather to clean out the garage a bit too so I can play with placement.
    oh.
    ... and my apologies if these've been suggested already...
    did the OP consider these?
    I put a set of these on my Dynaco SCA-35 when I was using it up at the then second house in NH, mostly 'cause I am lazy.
    They're kind of soft ('gold plated' brass) and the banana socket is screwed into the adaptor.
    They work OK. They're not fabulous, but they're OK.
    https://www.partsconnexion.com/CONNEX-74405.html
    One may find these on eBAY from all over the world; personally, I felt better buying from Parts Connexion. YMMV, tho', of course.
    9608227418_c66be7a0e6_b.jpgDSC_6212 by Mark Hardy, on Flickr
  • Faustin
    Faustin Posts: 1,151
    ^^^^ Using the screw to banana with a 1965 Fischer X-100 They work great.
  • delkal
    delkal Posts: 764
    edited March 2019
    Faustin wrote: »
    Looks great but I would shrinkwrap the bananas (or at least cover them with Electrical tape). It looks like one moderate tug when you are messing with things and you would have a short.
    Lets just say that would make me nervous
    delkal wrote: »
    Faustin wrote: »
    A transformer coupled vacuum tube amp is perfectly happy with a short-circuit across the secondaries -- it's open circuiting the OPTs that can lead to pretty serious damage. :|
