RDO-194 vs TL / RDO-198
Braddles63
Hey guys.
I have a pair of SDA 2B's here in sunny Australia.
As the title suggests im wondering if doing the TL and installing the 198's is a worthwhile improvement over a simple 194 install.
Cheers
Brad
Cheers
Brad
It's a fact that the 194's will always be an improvement over the sl-2000's. And the 198's require a little more work (regarding the install of the 5.8uF caps). But it's well worth the effort.
I did the the TL mod to my 2B's last year...never looked back.The Night is Dark and Full of Terrors -
Yes it is worth it, for the 2B's the cost is not that much, I suggest you swap out all Caps and Resistors while you are there, and get rid of the nasty Polyswitch, and replace with a .5 ohm Resistor as well..
Absolutely worth it.Political Correctness'.........defined
President of Club Polk -
Thanks Guys
