LSi15 Grill
Mysterious forces attacked my speaker and I am in need of a good LSi15 grill. I don't think it matters but it is the right side.
Stan
Stan
Main 2ch:
HT:
Other stuff:
  • K_M
    K_M Posts: 1,631
    Do not have a grill for sale, but just curious is your damage of the plastic frame or the fabric cloth protection screen?
    I just redid 2 of the fabrics and it was fairly easy but a bit tedious.
  • teamjhertz
    I might have one let me double check
  • skrol
    skrol Posts: 3,483
    The plastic frame is cracked in a couple places. I called Polk CS and they said that they were not available. However, when I emailed their CS about what type of adhesive I might use, they gave me a part number and said $35. I'll give another call tomorrow.
    I'm doubtful that they have it so I'd still be interested if someone has one to sell or if they know of a good adhesive to use.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • teamjhertz
    teamjhertz Posts: 363
    edited March 2019
    Just sent a pm
  • teamjhertz
    Two part epoxy might be worth a try
  • skrol
    skrol Posts: 3,483
    Just responded to your PM. I have had some luck with JB Plastic Weld on a lot of plastic things.
    Stan
    Main 2ch:
    HT:
    Other stuff:
