best rooftop antena?
dave shepard
dave shepard Posts: 1,334
edited May 2004 in Electronics
This weekend my wife and I desided to upgrade to HD Directv. We went with the Total choice plus W/HBO we are not in the right area to recieve local channels for 4 rooms and a monthly rate of $60.99 for the first 6mo.'s then $70.99 for the last 6mo.'s. Our cable with 1 HBO would have been $76.00 mo. and not even in stereo to boot. I was wondering if anybody has any opions on another place to look into rooftop antenas other then RS or are they the best place to get one? In the past I have gotten them and put them up (for parents when they lived in FLA) and thought that it worked good but was wanting to look at others before getting one. The one channel we watch is Fox from Cleve., OH (70mi away). Are there any better ones that can reach out further then the best RS model?
Dave
Post edited by dave shepard on
  • stevew14
    stevew14 Posts: 130
    edited May 2004
    Dave,
    I got the most expensive vhf/uhf RS had at the time. I had tried just the uhf, as that is what most digital local channels are broadcast on. It was much cheaper and worked quite well (when mounted high up on the roof). However my PBS digital channel was the only one that was broadcast on a vhf frequency, so I took the uhf back and bought their biggest combo. It works great! I am about 70 miles from the broadcast towers for most of my locals, and it picks them up fine. Even when the Direct TV signal breaks up sometimes, I can usually count on my OTA reception. I forget what I paid for the antenna and mast, I think it was on clearance or something. I want to say it was about 70.00.
    There may be better choices, but I think if you get the longest range you can find, Radio Shack should be just fine.
  • danger boy
    danger boy Posts: 15,722
    edited May 2004
    i use one of these for OTA HDTV Terk TV55
    not to big and it's easy to mount. so far it's working pretty good.
    PolkFest 2012, who's going>?
  • nebborjk
    nebborjk Posts: 425
    edited May 2004
    There is no such thing as a HDTV antenna. Any UHF/VHF antenna will receive both analog and digital signals.
    Proud SOPA Member since 2005!
  • wlrandall
    wlrandall Posts: 440
    edited May 2004
    No there is not...BIG marketing scam. All of the HD channels fall into the existing UHF/VHF bands.
  • dave shepard
    edited May 2004
    Thanks guys,
    I have put up twice for parents (baaad Fla. storm knocked it down) the biggest one RS had for recieving Orlando stations from Edgewater (near Daytona) and it did it very well. I didn't know if there was an even better one but RS will probably be good enough.
    One more thing if I do put one up can I hook it it the sat. dish (like the add-on OTA atenna for sat) and get the recievers to show the channels on the guide?
    Thanks again
    Dave
  • nebborjk
    nebborjk Posts: 425
    edited May 2004
    Yes. Your program guide will show your local channels from both DirecTV and OTA. You will need to run the "search for channels" feature on the STB. Also, note that you will probably have 3 or 4 different listings for each of the big 4 stations.
    Example: (my CBS is channel 12)
    Ch. 12 - DirecTV
    Ch. 12 - ANT.
    Ch.12.1 - ANT Digital (the HDTV Station) this channel is remapped from its actual channel of 31.
    Ch. 12.2 - ANT, Weather radar loop
    NOTE: Some PBS Stations are running up to 6 sub channels.
  • dave shepard
    edited May 2004
    Thanks I was hoping That would be the case. It would have ended up being one more PITA button to push to watch something else if that wasn't.
    Dave
