Screen noise?
superbrett
Can anyone clear up why I get this horriable fuzzy static when a commercial pops up text on my screen, it never did it until this afternoon.
I havn't moved the centerchanel, which is the only one close, and it's sheiled at that.
It's annoying as hell.
Also, I've heard I can get great results from some "video calibration programs"
Any thoughts on these?
Thanks.
Thanks.
"Looks good from far, but far from good!"
Post edited by superbrett on
My best guess is that a cable has degraded or that your power is dirty. As far as the calibration, getting it professionally done will yield outstanding results. Of course whether it's worth it or not depends on your set. But yes, the calibration dvd's are a great value and should improve the picture quality on your set, though they won't do anything for the static.
What kind of TV do you have?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Samsung 30" widescreen...it's less than 6 mo. old!
I know samsung dosn't make the very best stuff....but still."Looks good from far, but far from good!" -
try takin some steel wool and cleanin the cable connection into the house, that got rid of alot of static for me
edited for typos lol
