Qobuz...
  • Mikey081057
    Mikey081057 Posts: 7,127
    I couldn't find:
    Tito and Tarantula
    Cracker (Kerosene Hat)
    on Tidal
    Garage | Polk Monitor 5B's
  • machone
    machone Posts: 1,588
    My problem is that I can not get it to function. Lags terrible or just locks up.
    No problems at all with Tidal.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Mikey081057
    machone wrote: »
    Did you restart your modem and router?
  • machone
    machone wrote: »
    Not while troubleshooting Qobus but I did a firmware update on the router within the last month and rebooted everything. I will take another look at it.
    However, rebooting does not explain why I can't get it to stream to my cell phone. It takes about a minute to play a few notes and then it stops.
    Maybe there is some setting somewhere that I have missed or messed up.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • codycatalist
    codycatalist Posts: 2,661
    machone wrote: »
    machone wrote: »
    I had a similar issue with the 24 bit files. I have decent internet (50Mbps) but the 16 bit files played flawlessly for me.
  • CGTIII
    CGTIII Posts: 1,279
    After internet bandwidth, I know low jitter is important. Anyone know reliable internet jitter tests AND acceptable results for Qobuz and Tidal at Hi-Rez levels and above?
    Boston - CR7, CR6s, CR4s.
    ​Thompson Adventures, Inc.
