Spider-Man Superbit
Shizelbs
Shizelbs Posts: 7,433
edited May 2004 in Music & Movies
I'm not sure how long this has been out, but is anyone planning to get/has bought the superbit version of Spider-Man? Any thoughts? I never bought the DVD when it first came out, so, I may get the Superbit instead.
Post edited by Shizelbs on
  • ohskigod
    ohskigod Posts: 6,502
    edited May 2004
    curious
    what would be the difference between the 2?
    i have no idea what super bit is
    Living Room 2 Channel -
    Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
    Upstairs 2 Channel Rig -
    Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
    Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites
  • danger boy
    danger boy Posts: 15,722
    edited May 2004
    i haven't seen or heard that Spiderman was going to be released on superbit DVD.
    super bit is higher quality mastered DVD than your regular DVD. There is usually a DD and DTS sound track on the disc. There are no extras on the DVD. They instead use the space usually reserved for the extras to up the picture quality of the movie. It's a higher resolution picture than your regular DVD's. some people say that they can't see any difference.. other people say they can see a difference.
    a good superbit movie to check out is The Fifth Element. I noticed better picture quality on the superbit version over the regular release one. Remember the increase in picture quality is usually pretty small. you have to look real close to notice any difference. If you have an older TV, you may not notice any difference at all.
    PolkFest 2012, who's going>?
  • Grimster74
    Grimster74 Posts: 2,576
    edited May 2004
    Just happened to be browsing around and come across this link.
    http://www.joblo.com/dvd/releasedates.htm
    Check out June 1, 2004
  • Shizelbs
    edited May 2004
  • johnny_utah
    johnny_utah Posts: 117
    edited May 2004
    Superbit is only sold by Columbia/Tristar. They say that it is a higher quality DVD. It is, and it has bit rate of about 8-10mb. Other DVD's not produced by Columbia/Tristar can have the same bit rate but since they are not Columbia/Tristar movies they are not called superbit, but in fact hey are they same quality (ex. Shrek). To check this some DVD players have the ability to show the bit rate. Also Superbit titles all have a DTS audio track compared to the standard releases that many times only have Dolby Digital audio. Just a little info.
