Consolidating :: HT Bypass w/Integrated Amp and Bridged HCA-1000 Center?
msg
Hey guys, I've been wanting to consolidate gear for a while, and I'm mulling this over a bit more seriously now. This would be for a 3.1 system.
What are your thoughts on
I've seen mixed perspectives on bridging.
The 706c seems pretty big, and is 8Ω
Here's the Parasound info on the HCA-1000A
- Surround Processor > HT Bypass on Integrated Amp > Mains
- Parasound HCA-1000 in Bridge Mode > LSiM706c Center?
Seems like a lot of power just for the center channel.
If you are crossing over your center around 80hz, you won't need much power- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I used a little audiosource amp two in bridged mode to power a cs400i crossed over at 60 hz. (I would use 40 hz but it’s in a cabinet. I like to run the center full range if possible). Anyways, it sounded great, really full and clear. Now I have a b&k 3 channel 200 wpc. I actually liked the audiosource better for the center. All that to say that if you have that amp laying around go for it. If you are buying new just get an hca 750.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
