If you like horns...
OldSchoolPolk
in Speakers
This is a surprisingly clear explanation of how horns work. I don't know how accurate it is but it helped me understand the concept
.world's largest horn shatters glass
HT: Marantz NR-1603, Oppo 981, Def Tech SM55, SVS PB-1000
BR: iPad Mini, Audio Engine A5+
2C: Parasound ZDAC V.2, Sony DA80ES, Sony XDR-F1HD, SVS Prime Tower, JSE .6 Infinite Slope
Office: MBAir, Focusrite Scarlett 2i2, JBL LSR-308
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM
OK, so it's obvious I'm inept at attaching links from Youtube, Let the laughter begin. But if you try that phrase in Youtube you should find it
Projects: Polk RTA12, Polk Monitor 7, Revox B225CD, BIC 3-TM -
Apologies, your post led me to this place...
Jay
Jay
I just went in a big circle.
I reckon this is the YT video to which the OP was referrin'.
https://youtu.be/pFEB0chiuJA
Horns are simple enough in principle, they're acoustic transformers (impedance matching devices).
In practice -- to make one that is well behaved across a broad range of frequencies... that's (still) a challenge!
The red horn on that video isn't particularly large; there have been numerous "room sized" horns built for hifi over the years. Steve Deckert at Decware turned a basement into a bass horn --- and cracked the foundation due to a problem with standing waves or resonance in the process
Here's another 'crazy basement horn' (clickbait type of link, for which I apologize):
https://gizmodo.com/horn-subwoofer-takes-up-crazy-mans-entire-basement-5025867
Nelson Pass's ironically named Kleinhorn (small horn auf Deutsch) is/was... well... moderately large. Probably about the same size as the one in the YT video, given the area of the mouth.
https://www.passdiy.com/project/speakers/the-kleinhorn-part-1
Those Lowther drivers are nominally 8 inches in diameter, to give a sense of scale (or you may notice a tt on the shelf).
the problem is that the speed of sound is fairly slow, so the wavelength of bass tones is pretty long. The wavelength of a 20 Hz sine wave (tone) is 56.5 feet.
Thus, if one wants to make a horn with good performance at low frequencies, one usually folds the horn (like the Kleinhorn above, or the famous Klipschorn folded corner horn).
Here's a straight 30 Hz (wavelength 37-2/3 feet) bass horn (well, a pair of 'em, by the looks of it).
http://vincent.brient.free.fr/bass_horn.htm
As Lt. Columbo would have said...
any discussion of horns is incomplete without...
The Chrysler air raid siren.
"Yeah, it's got a Hemi in it."
https://youtu.be/04SMJlwosZ0 -
Oh.
And.
To shatter a glass, you don't need a Horn(e), or even a Bassey.
Just a Fitzgerald.
Or a Memorex.
https://youtu.be/MjV0DswlXeo
mhardy6647
I love these horn postings."Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Cool.
I of course, am being completely ironic, posting that stuff.
I mean, who could bear to listen to them old things?!
ahem.
