Loaner preamp
As luck would have it, I'll be shipping both of my preamps out tomorrow to for servicing. Great timing! This means I won't be able to use my system and keep logging hours on my new PMC speakers.
Simply wondering if anyone has a loaner preamp they'd be willing to let me use while my others are in the shop. Naturally I would cover shipping in both directions.
As several members here know, I am extremely meticulous about the condition of my gear. I actually dust all of my equipment, speakers, and rack with a soft microfiber towel before every use. Hopefully that shows you the care I take with it. You can rest assured that it will return to you in exactly the same condition it was sent in.
  • DaveHo
    DaveHo Posts: 3,583
    If you can get by with 2 line level inputs, a Schiit Sys may cost you less than shipping a loaner both ways. It's passive, but at the lower levels you seem to listen at, I doubt you'd have trouble getting sufficient volume.
    Clipdat Posts: 13,100
    I was looking at the SYS last night. It would cost me $62 total with shipping & tax.
    I guess the only downside to buying it would be that I would be stuck with it afterwards.
    mhardy6647 Posts: 35,375
    Clipdat wrote: »
    I'll bet you could find a home for it with only a nominal net cost to yourself :)
    Sadly, there are preamps here, but they're all kind of suffeing from the Isle of Misfit Toys syndrome. I don't think any of them'd be satisfactory to you, otherwise I'd be happy to send one along.
  • maxward
    maxward Posts: 1,728
    If you buy the SYS, I’d buy it from you when you’re finished with it.
    Oh cool, thanks! Let me check in with Dr. Skipperton III, Esq. first but that sounds like a plan.
  • DaveHo
    DaveHo Posts: 3,583
    Clipdat wrote: »
    I find all kind of uses for mine. I'll frequently set up a temporary system in my shop using whatever extra speakers or amps I have combined with the SYS, a DAC & CCA. It's currently serving duty in the bedroom system. Found it's way in there because the pre I was using started acting wonky. Turns out the pre-amp is fine, but it sounds nice enough that I haven't bothered to swap it out yet. The only real downside is even wide open, it will not allow most source components to push an amp to full power. Rarely an issue unless you're in full time rock-out mode.
  • joecoulson
    joecoulson Posts: 4,943
    He is a doctor of fine Italian Audioogy.
  • verb
    verb Posts: 10,176
    I've got a Rotel RC-1580 that you are welcome to use. Let me know brother!
    gudnoyez Posts: 8,183
    I've got a couple of Adcoms pre amps, in the storage area but nothing like Skip could offer you.
    Hey thanks a lot! That might be the most economical option!
    Still waiting to hear back from what Skip's got in his pants.. er uh, in his fun bags.. crap, I mean up his sleeve.
    EndersShadow Posts: 17,741
    edited January 2019
    I’ve got a Harman Kardon Signature 2.0 I could loan out.
    Even w original box and packaging (though I’d firm it up lol).
    It would be shipping from Indianapolis
    So I was thinking about this today (and my buddy Scott @msg also brought it up), I have a Schiit Asgard 2 headphone amplifier that has a "pre out" on the back of it that's controlled by the volume knob on the front. I've never tried this particular function of it before, so I will give it a go tomorrow and see how it works.
    Also, I'd like to sincerely thank everyone who commented with offers of loaner preamps, stuff like this is what makes our forum awesome.
  • joecoulson
    Glad you got it worked out. Was boxing up the stellar gain to ship out but oh well.
    Clipdat wrote: »
    It certainly should. The only drawback I'd see (based on the photo) is that this Schiit gizmo only has one input (yes?). If so, you'll either have to add an outboard switchbox, stick with one source, or swap connections to change sources.
    Of course, for all I know, maybe you only want/need/have one source for this particular application(?).
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    Another example of why CP is such a special place. Helping each other out in times of need. Hope everything works out for ya Drew!
    Loaner pre amp ? Is that a pre amp sitting in a corner facing the wall....all alone ?
  • maxward
    “He was quiet. Kept to himself.”
    maxward wrote: »
    Was a nice pre amp....until one day he picked up an axe and wiped out the whole system. :)
    edited January 2019
    I've got the Schiit Asgard 2 hooked up for preamp duty and apparently it doesn't switch off it's class A headphone amp circuitry when just doing preamp mode, because it's running hotter than a two dollar pistol as usual.
    There is a slight hiss in the tweeter and a faint hum/buzz heard in the woofer with nothing playing. Probably just a side effect of the cheap transformer inside of it. I have the ground lift switch engaged on the Bryston, so I don't think it's a ground loop. Anyway, it's not audible with music playing so whatever.
    Sound is adequate! It's a little brighter/hotter up top and less elegant and smooth all around, but it'll do for 3-4 weeks I suppose.
  • joecoulson
    Kudos to you for dealing with a less than ideal situation in stride.
    It will be worth it when the Backert comes back shiny.
    It's definitely a few notches down from what I'm accustomed to hearing from my system. I don't really find it that enjoyable to listen to, but oh well. Like you said, it'll just make the Backert sound that much better once I get it back.
    Clearly it makes a better headphone amp than a preamp.
    Maybe I should still consider giving @ZLTFUL's SYS a go. I feel like I'd probably enjoy that more.
    I know Bob and the boys down at Backert labs will have that puppy like new in no time. Great bunch of people over there.
    If I may ask, what needed servicing in the pre ? Isn't it fairly new ?
    tonyb wrote: »
    https://forum.polkaudio.com/discussion/comment/2475740/#Comment_2475740
  • GlennDog
    GlennDog Posts: 3,158
    PM sent to OP . . .
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    I just missed out on a Cambridge Audio Azur 851E preamp I was going to buy, by literally 2 minutes. It sold while I was on my way to work.
    Clearly, your priorities are woefully misguided. Work'll be there later.
  • joecoulson
    Would have been a great acquisition but alas, was not meant to be
    Well why can't I find another one for sale anywhere? Seems like they don't come up for sale too often, and it appears that they are no longer manufactured. Although the integrated in the same line still is: https://www.audioadvisor.com/prodinfo.asp?number=CA851A
    Maybe this is why Cambridge discontinued the 851E:
    "The 840E's resistor/relay volume attenuation used under-spec'd (power/heat) resistors that result in a "runaway/shorting" volume level - complete with accompanying pops, crackles, and a hellish fear of our beloved hifi (amps/speakers)."
  • joecoulson
    Whoa. That’s scary. If I understand what they are saying, could be a equipment ender
