Streamer Recommendations
  • gyosa
    gyosa Posts: 770
    Glad you like it .
    I have the 851n which is fantastic !
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • displayname
    displayname Posts: 1,229
    kevhed72 wrote: »
    Update on the Cambridge CNX experience so far. First off, I have no issue "finding it" to connect with either with the Cambridge app or Tidal Connect. The biggest fault I found with my previous streamer was the issue connecting via the app to actually listen to music. The build quality is decent but would be crushed by my MF amp if I placed it on top of the Cambridge. Plenty of connections and turning on and off is not a hassle to re establish a connection. The rotary knob in the front is a nice feature but mine seems wobbly or "lose" to the touch which is annoying. Anyone else notice this with theirs? Last note on the sound - I took my Benchmark DAC2 out of the chain due to an overly analytical sound which wore on me with high res recordings. The internal DACs are, as Larry David would be say, pretty, pretty, pretty good.
    I don’t know that I’ll call the knob on mine loose, but it has some wiggle. It feels intentional to me, but it certainly could be a little planted.
    I also preferred the CXN vs benchmark. Preference more than anything I believe.
    I still get curious about the modwright upgrade vs different gear upgrade. But still not curious enough to pull the trigger.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
