SDA-CRS Blade Blade
Thinking of taking a trip tomorrow to pick up another set of Polks. These are Blade-Blade SDA-CRS single SL 2000 and of course two MW each. I have been searching and reading an hour now and I cant recall or find a place that tells me if these are the ones that have the crossovers that are like ones in my SDA 2b's. One more thing, do these have real wood veneer or are they that plastic "wood grain" stick on stuff ?
  • VSAT88
    VSAT88 Posts: 1,325
    Ouch, so the two piece crossovers with all the extra $ parts..right ?
  • VSAT88
    VSAT88 Posts: 1,325
    Also no AI-1 interface can be used ???
  • VSAT88
    VSAT88 Posts: 1,325
    OK, I think I found it. The ones I would be looking for would be the 1987 model SDA-CRS + with Pin Blade. The drawing I looked up looks the same (capacitors and resistors anyway) as my SDA 2b's.
  • VSAT88
    VSAT88 Posts: 1,325
    Guess If I wanted to go a little crazy 2 6511's two Gimpod boards and two 198's and I could have a NICE set of pin blades right ? LOL. 225.00 is what they want. If I could get them for 100.00, 125.00 it would be worth it I guess. Those are damn nice there, the ones you got. For 60.00 I would not have been typing to ask questions because I would have been too busy listening to them. Thanks Brother.
  • VSAT88
    VSAT88 Posts: 1,325
    Is that a Sequoia those speakers are sitting in ? I kept looking at the speakers then the SUV and I thought my mind was playing some kind of trick on me. I have a Sequoia and that would be the truck I would ride in to go get the speakers....Same ones I am looking at buying are sitting in your truck and and and.. Huh ?...
  • VSAT88
    VSAT88 Posts: 1,325
    I like that last expedition best.
    Tony M Posts: 11,731
    la2vegas wrote: »
    8obzjawmo7bj.jpg These are my blade/blades. :)
    No blankets? :o:D
    la2vegas wrote: »
    It's an expedition. It's made a cameo in several of my purchases. ljx59r5lqat8.jpg
    No blankets ? :D tisk, tisk. :D
