Subwoofer delay
RaulTOB
Hi good afternoon, I buy a Polk psw10 subwoofer and I am experiencing the following problem, the sound emitted by the subwoofer is delayed a fraction of a second with respect to the main speakers, let's say that a double bit is heard instead of a single blunt bit, you hear the bit of the main speakers and a fraction of a second later you hear the echo of the subwoofer, is there any way to remedy that problem of signal delay?
P.S. I have the main speakers connected to the output A of my amplifier and the subwoofer is connected to the output B of my amplifier. In this way I can activate and deactivate the subwoofer from the remote control.
Thanks.
Ing. Raul Torres-Orozco
Thanks.
Which amp do you have?
Does the PSW10 have speaker outputs? If so, you could try wiring the speakers through it and see if that helps. Although you'll lose the ability to switch it off.
rpf65: Yamaha RS202.
mlistens03: Thanks, I will tray that way. -
From the instruction manual:
Run one pair speakers from speaker out “A” on your amp to speaker in “a” on you sub, observe polarity. Then run a pair of speaker wires from speaker out “A” on your sub to one of the speakers you have, observe polarity. Repeat for side “B”. -
rpf65: Thanks, I will try
