Glue for loose power port?
My 705's came with the power port plastic rattling in the box underneath the speaker. I had snapped it back into place and all is well. But it has a little bit of give left and right turning in place. Is it worth pursuing applying some adhesive there? The other power ports seem secure and don't move at all. I'm not hearing any rattling or notice any movement to this piece even in playback with deep bass. Just wondering if I should remediate this small issue.
Yes you should put it back in place and glue it.
I've used Aleene's' adhesive/glue to do this same project.
I use the clear that comes in a squeeze bottle. You can get these glue most everywhere.
Maybe it doesn't say clear. I have 2 types. One is white and dries clear. Hobby shop. JoAnn's' craft stores.
https://youtu.be/kOSHpn3HAmQ Most people just listen to music and watch movies. I EXPERIENCE them.
I've used Eileen's' adhesive/glue to do this same project.
Thank you will look into it.
