Solid Tech Discs of Silence
Excellent near mint condition. Comes with (5) springs each unit and can sustain max load of 200 pounds. Stiff springs, worked well under my 60 pound TT. Asking $225 shipped worldwide, I can possibly USPS via APO next week for US buyers.
Put some spring in your component isolation with the precision Disc of Silence from Solid Tech. These highly effective component discs feature a piston-like central hub that is suspended and isolated from the outer cylinder thanks to three or six suspension springs.
The resonant frequency of the tension springs is about 5 Hz with a normal load, which means that the effective isolation starts at about 8 Hz. That will effectively keep a wide spectrum of vibration-borne noise out of the signal change, giving your music the purity it deserves.
A set of four Discs of Silence can handle a load of up to 200 lbs.
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • verb
    verb Posts: 10,176
    Those are cool! And look to be well built!
  • Thanks, they are very well designed. I used them under my front end to isolate from my monitors, but changing up the system after a few years. I used 3 springs, and have installed the full compliment for shipping to new owner. They perform and look like new.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • rooftop59
    rooftop59 Posts: 8,120
    Sweet looking setup! GLWS!
    Game Room 5.1.4:
    Bedroom 2.1
  • dromunds
    dromunds Posts: 10,137
    VERY sweet looking set-up, especially the vinyl out-lay. GLWYS.
  • SIHAB
    SIHAB Posts: 5,558
    Wow! Great setup. :D
  • verb
    verb Posts: 10,176
    Yes very nice setup. What are those acoustic panels on the wall? Those look interesting.
  • verb wrote: »
    They are made of wood, just a local design of Mashrubiya (geometric Arabic pattern), maybe they do a little diffusion. room is mainly treated on ceiling and far wall with lots of absorbers.
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
  • doctorcilantro
    doctorcilantro Posts: 2,028
    bump
    For Sale 2019:
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
