Polk RT1 A1 Not Driving Correctly From Denon Amp
I have 2 Denon Amps:
Denon AVR 1613
Denon AVR X1300
When I hooked up the RT1 A1 speakers to the Denon 1613 they seemed flat. So I am wondering if the amps are insufficient for these speakers. Also, does anybody know a way I could run these speakers off a separate amp while the Denon plays the surround sound.
    tonyb Posts: 33,072
    the 1613 should run them just fine, either would really. You don't need a separate amp. Your problem is most likely in the setup menu. Re-read your manual, see if all the adjustments are made correctly.
    pitdogg2 Posts: 27,073
    Neither one of those receivers have pre-outs to add an amp. both are very low powered products. To run anything more than 2 speakers would DRASTICALLY reduce the power to every other channel. At 75wpc and 80wpc by the time you have 5 speakers playing you are down to about 25-30 wpc max if that.
    I can understand why the speakers sounded flat there is no power to be had with either let alone any current to push any power.
  • I am running these speakers while using Energy 5.1 speakers. Are the speakers meant to be run independently?
  • K_M
    K_M Posts: 1,632
    Denon AVR 1613
    Denon AVR X1300
    Running just one set of speakers? Are you in 2 channel mode?
    What Room EQ, and tone or Equalizer settings, and so on.
    Is this with music??
    Do you use a sub or run speakers full range?
    Define flat please?
  • K_M
    K_M Posts: 1,632
    What channels of AVR are you using?
    More details needed.
  • Center, Sub-Woofer, 2 rear, and 2 Front. I substituted the two Polk speakers for the 2 Front.
  • Was also wondering why these speakers have 2 sets of speaker wire inputs...Does it matter which set is used? Upper or Lower..
  • rpf65
    rpf65 Posts: 2,127
    If you switched front speakers, did you re-run your calibration program?
    Any time you make changes, even moving existing speakers, it’s highly recommended that you re-run your calibration program.
    F1nut Posts: 51,798
    edited December 2018
    You have to run the calibration program any time you change anything. Did you?
    Edit: Ha, as I was typing I see rpf65 beat me to the punch. B)
    Bi-wiring is the point of those. You should have a jumper or plate that connects the two together and you just plug your speaker wire into either input.
    Could it be that you may have only connected it to only one set without the jumper? That would cause it to sound "flat".
  • mrloren
    mrloren Posts: 2,474
    Re-calibrate all the time, move a sofa = re-calibrate
    Yeah if you don't have a jumper in there it will sound flat. Either the brass plates OR speaker wire.
  • Where did you buy this connector from?
  • mrloren
    Made it myself. got the spades from Amazon and used 10AWG Furez speaker wire.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Does this question mean you're missing the brass connectors like on the picture codycatalist posted above?
  • The brass connector came with the speaker; but not this connection wire.
  • rpf65
    rpf65 Posts: 2,127
    The brass connector will work by itself, so long as both of the binding post nuts are tight on each set of binding posts. The wire is a inexpensive upgrade.
  • mrloren
    Removing the brass connector and adding a speaker wire jumper is the best lowest cost upgrade anyone can do.
  • mdaudioguy
    Let us know if that "corrects" the problem. If the brass jumpers were already in place, I doubt the improvement from replacing them with wire jumpers will take those speakers from flat to full of life, but maybe I'm wrong...
    Did you re-run the calibration?
  • Interested to know if you have had any joy with your sound?
    FWIW I always find it better to have to main cables running to the tweeters rather than woofers.
    Maybe the jumper cables are too thick to carry to the tweeters. Make sense to swap them around to me
