Modded Speakers
Early B.
Early B. Posts: 7,900
edited May 2010 in Speakers
Just curious -- has anyone on this forum ever attempted to modify their Polk floorstanding speakers? If so, what was done and what were the results?
"God grooves with tubes."
Post edited by Early B. on
  • dam
    dam Posts: 9
    edited April 2004
    read my post from 4 15 its on the third page titled sda crs driver upgrade the morel nm 164 mid bass drivers are much improved over the 6 and a half inch polk drivers in my sda these are a perfect driver upgrade for any of the sda or moniter series polks .I talked to a tech at parts express who recomended them and also morel usa they play cleanly and much louder without the bottoming i had with the original drivers .they have double magnets and 3 inch voice coils and rubber sourounds.
    system includes polk sda
    crs ,velodyne uld 15 sub,adcom gfa 555 amp and gfp 555 preamp and yamaha souround amp for center and rear channels
  • Early B.
    edited April 2004
    Would your experience with those drivers be applicable to the Rti series?
  • Tour2ma
    Tour2ma Posts: 10,177
    edited April 2004
    Not me personally, but several members have worked on their Polks.
    raife has done as much modding as anyone 'round here. Particularly upgrading crossover components. Nice thread here on this, but buried in another topic...
    I know F1 has upgraded to cardas 4-way posts. He's documented this at least twice in threads.
    RussMan swapped out his SL2000 tweeters for the replacement SL2000T's
    More later,
    Tour...
    Vox Copuli
  • Airplay355
    Airplay355 Posts: 4,298
    edited April 2004
    ezc or sumthin like that changed the xo in his lsic to that of an lsi9 so the mid drivers received the same signal
    VR3 Posts: 29,662
    edited April 2004
    Is will be very hard to mod any driver component on the RT series unless you really know what you are doing....
    First, the tweeter *mounts* into the baffle, and when I say mount - I mean pops in like a 20 dollar toy at walmart. Then the depth of the tweeter hole limits the magnet size, depending on which model you have ---
    The midbass section has to have a flat ring (I guess thats what you would call it) so it can fit with the baffle -- since the RT series uses no screws in their drivers, it is all a matter of fit and letting the baffle and other materials to hold them in.
    The crossover, atleast the RT35i would be easy to mod, but they glued the components to the board, so good luck there as well. The only really easy upgrade is wire, but then you have to be careful about your size of wire, because they cut a hole in the tweeter hole for the wire to pass through and it is only so big.
    By the way, this is based on the RT35i, other madels may vary.
    Hope this helps :D
  • Tour2ma
    edited April 2004
    :confused::confused::confused:
    More later,
    Tour...
    Vox Copuli
    VR3 Posts: 29,662
    edited April 2004
    Tour,
    LoL, the tweeter *pops* into the baffle, like a toy does -- Snap together....
    Very hard to take out, easy to put in -- Snappy...w00t w00t
  • goingganzo
    goingganzo Posts: 2,793
    edited May 2004
    i red a site on modding a rt book shelf speaker the xo and it was susto be realeu good
  • dam
    dam Posts: 9
    edited May 2004
    hi early the polks i moded were older sda with 6 1/2 inch mid bass drivers mine are held in with screws. im not familiar with the rti series the drivers i used for mine are a higher quality driver than the originals .the morel tower transmision line tower speaker that uses two of the same drivers in each one cost 4 grand a pair i bought 4 drivers from morel usa in brookline ma. for $304 I play a lot of rock and these play as loud as i can stand without bottoming out like the originals did on low bass notes
  • 20hz
    20hz Posts: 636
    edited May 2010
    I was going to try changing the caps on my monitor 5's to a Solen type cap ?
    Has anyone tried this and will it give me a audible inptovement ?
    The silver coil tweeter sounds really nice in those I just wonder if there is room for improvement ?
    I dont drive these hard in fact they operate from 100 hz and up the subs take the low end .
  • Face
    Face Posts: 14,340
    edited May 2010
    Use Sonic Caps or Claritycaps, I'd avoid Solen.
  • george daniel
    george daniel Posts: 12,096
    edited May 2010
    Anyone ever hear from Brad? I pm'd him about a year ago--but have not heard back from him.
    BTW--sonicaps--they may have a sale now too.
  • Jetmaker737
    Jetmaker737 Posts: 1,144
    edited May 2010
    Wow! A six year old thread brought up from the dead. I think that's a record.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited May 2010
    George, been wondering the same about Brad myself. Phil and I were just recently talking about his absence.
  • 20hz
    20hz Posts: 636
    edited May 2010
    I wonder about replieing to old ones too , I just hope people are listening :)
  • 20hz
    20hz Posts: 636
    edited May 2010
    Face wrote: »
    Thanks for the advice :)
