sub box help
MexicoDan
MexicoDan Posts: 14
edited April 2004 in Car Audio & Electronics
I've got a 96 Ext Cab Chevy and two DB10's ready to go in. My problem is a good sub box with a space needed for an amp. I like the forward firing duel box, but it doesn't seem to have any space for the amp. I'm leaning towards the Hifonics Brutus 1500D. I already have an amp under the driver seat so I'm not sure where Brutus can go. It doesn't look like it will fit under the passenger seat. Any ideas?
Post edited by MexicoDan on
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    maybe you can mount the amp on top of the box? or, if theres only a little room, put your current amp there, maybe the brutus will fit under the drivers seat?
  • exalted512
    exalted512 Posts: 10,735
    edited April 2004
    how about doing it like this?
    i have my amps mounted on the back wall with no problems
    youre probably going to pay a pretty penny for a custom box made to have an amp on it...i cannot mount an amp to my box because it doesnt have the space for it
    youd have to cut out some of the center and drop it 5" so itd have room to cool itself properly
    -Cody
