(4) NIB RDO-194's $180 Shipped
(4) RDO-194's New in Box from 2011
PayPal F&F, >100 posts
$180 shipped
These were purchased from Polk in 2011 for speakers that I ended up selling before upgrading. Still in the original boxes.
    pitdogg2 Posts: 27,372
    Dang Craig if you stumble over some unused 198's pm me ;)
  • vcwatkins
    vcwatkins Posts: 1,992
    I believe I've used them all, but I'll double-check.
  • vcwatkins
    Price lowered to $160.
  • verb
    verb Posts: 10,176
    Good deal here! Good seller! :smile:
  • gyosa
    gyosa Posts: 770
    Craig ,
    From what you can tell, will these require a #10 washer to prevent cracking ?
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • vcwatkins
    Not absolutely required imo - I never used washers and never had a problem; but I was careful not to over-tighten. Washers would eliminate the risk of over-tightening and may allow higher torque when using hurricane bolts or Larry's tweeter brackets.
    I do have a 100 post min on this; so if you're interested, you can buy through the ebay listing.
    Thanks for the interest,
    Craig
  • gyosa
    gyosa Posts: 770
    Ok,
    If you change your mind regarding the 100 post min ,
    Lemme know ...
    Bk
  • Dr_Wu
    Dr_Wu Posts: 356
    edited December 2018
    Regarding the washer, I installed these tweeters in my CRSs. Rather than routing out the baffles, I trimmed the plastic outer flange from the new tweeter. They then fit in the old cut-out and screwed down flush to the baffle, negating the need for washers. Used hurricane nuts and machine screws. I've experienced no vibration or cracking issues.
  • vcwatkins
    Thanks Dr. Wu, I'm with you.
    @gyosa , they're yours if you want them.
    Thanks, guys!
  • gyosa
    gyosa Posts: 770
    Thanks Craig ,
    I’ll check back in a day or two ....
    Gotta wait to see if my wife’s companies layoffs hit her ....
    Bk
  • vcwatkins
    These are SOLD.
