Integra Stereo Help
gatemplin
gatemplin Posts: 1,595
edited April 2004 in Car Audio & Electronics
I had my Alpine deck stolen 2 days ago, **** used a crowbar. Now I need help with the installation.
I have installed a few decks before but it was always pretty straight forward. Plug the harness in and plug the antenna in.
On my 1992 Integra, I can only find the harness, not the antenna.
Does anyone know if antennas are sometimes part of the harness? I have a electronically retractable antenna, does that matter?
Any help is appreciated. I am probably going to install a Sony MD deck
Graham
Post edited by gatemplin on
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    dont get a sony!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    hope im not too late...
    -Cody
  • gatemplin
    edited April 2004
    I know believe me, its actually an MD deck in another car I dont use.
    I figured out the problem, the thief hacked the antenna.
    Graham
  • exalted512
    edited April 2004
    ahh...that sucks...stupid thieves...i feel for you...
    insurance going to help any?
    -Cody
  • gatemplin
    edited April 2004
    No I am not going to claim it. I reported it to the police but I dont want my insurance to go up.
    Graham
  • exalted512
    edited April 2004
    yeah i hate that...its a lose-lose situation
    -Cody
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2004
    well.. here's what you can do...
    the antenna wire runs out to the antenna in two pieces:
    1: wire from antenna stud to interior
    2: wire from side of car to deck
    well what you do is go to radioshack and get an antenna extension wire.. maybe 1.5 foot I think... you may need two. Disconnect the old wire where it plugs from the harnesses wire to the one that goes to the fender. route the new extension cable in the same fashin under the dash as the old one
    then plug it into the deck :cool:
    ----IF---- you have enough antenna wire to put a new male end on it at the deck end, you can replace them instead, it will be a radioshack item as well, but needs to be soldered.
    Hope that helps.
    Here's a pic:
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • gatemplin
    edited April 2004
    Thanks for the help little car,
    I soldered on a new end. It seems to work fine now. Now I have to work on repairing the console.
    Graham
  • exalted512
    edited April 2004
    may God help you if your car is that jacked up after the thief got done with it:D
    -Cody
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    with a crowbar? i dont know if anyone(-thing/-being/-etc.) can help there...
  • gatemplin
    edited April 2004
    It isnt as bad as it sounds. I am gonna try to replace a couple parts but only if they are cheap.
    Graham
  • neomagus00
    edited April 2004
    even if they're kinda expensive, it's probably better to do it right the first time and then never have to worry about it again
