Kicker 11hs8 under the seat subwoofer - Sold
VR3
Never installed, manufacture refurbished.
Have 1 year after market warranty left
Originally had chose this model due to frequency response and power handling in this class. Oddly enough after my new door speakers broke in, I found the bass enough as I'm not. Super hardcore. With car audio.
150 shipped with paypal
According to the manufacture, this is whats included. So, yes, I believe so. I hope this helps.
Thank you as always
Amplified subwoofer
Wiring harness (17.5' Power input/ 8' Speaker level input/ 2' Ground/ 2' Remote turn-on)
In-line fuse holder
One 15 amp ATO fuse (installed in fuse holder)
Two 10 amp ATO fuses (1 installed in the chassis of the unit/1 spare)
Remote bass level control
Metal bracket (for mounting remote bass level control)
20' Remote cable (3.5mm stereo mini-plug on both ends)
2 Velcro mounting straps
Two 10-12 gauge crimp-on ring terminals
One 10-12 Gauge butt connector
4 Flat washers
4 Mounting brackets
Two 3/8" Self-tapping pan head screws (to mount wired remote)
Four 3/4" Self-tapping pan head screws
Eight 3/4" Self-tapping flat head screws
Four 1-3/8" Self-tapping flat head screws
Mounting template
Owner's manual (English/ Spanish/ German/ French)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
ok cool, maybe a F&F paypal at vr3mods@gmail.com
I might be able to get it out before Fedex closes today!
If it somehow falls through, I will take it.Shawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
Sounds good, go ahead and send me your address- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
This is sold. Thanks!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
