Forte model 3 with SDA
I have a chance to buy a forte model 3 and I understand that it's dual mono but am curious if it's also common ground for use with SDA. Searching online hasn't revealed a definitive answer, I posted the question on a classic audio fb group and only received private messages telling me it won't work and asking for the sellers info, lol. Can anyone help solve this mystery?
  • Dual mono would mean it is not common ground. You may be able to contact the maker and see if you can strap the grounds together or you can go with a dreadnaught.
    F1nut Posts: 51,942
    True dual mono means it's non-common ground as each channel shares nothing, especially the transformers, but some dual mono amps cheat by sharing a single transformer and therefore may actually share the ground. Looking at the guts of the amp in question I see a single transformer, so the only way for you to know is test the negative outputs.
  • FTGV
    FTGV Posts: 3,650
    edited November 2018
    The pic I was able to find show's stacked dual transformers. However it appears the negative speaker output connections are tied to power supply star ground. It does not have a bridged/ balanced output stage so could be used with SDA's. I could not find a schematic and could not from the pic tell if there are resistors isolating each channels ground individually from chassis ground. If there were simply strapping the two negative posts together would make it common ground.
    F1nut Posts: 51,942
    This is the pic I found.
  • FTGV
    FTGV Posts: 3,650
    That might be a pic of the model 1? Heres the one I found Jesse. http://audiokarma.org/forums/index.php?media/forte-model-3.1016/
  • FTGV wrote: »
    Thank you.
    Doesn't the interconnect cable essentially also tie the negative connections together?
    Yah and from the pics I've seen it looks like two transformers stacked. The amp is 2.5 hours away but is only $250 so it's a pretty good deal, no?
  • dankHugzNY wrote: »
    FTGV wrote: »
    Thank you.
    I'm going to leave this to the more seasoned people who can explain it better than I can. Curious though what SDA models do you have and is the interconnect cable pin/blade or blade/blade?
    F1nut Posts: 51,942
    FTGV wrote: »
    Here's a link to the one in my pic, definitely a model 3. Scroll through the pics.
    http://www.hifishock.org/gallery/electronics/forte-audio/power-amplifier/model-3-0-forte-audio/
  • Yeah and that one looks like a single transformer but the angle might be deceiving. I really wanna drive 150 miles to get it but only if it'll be okay with the SDAs!
  • FestYboy
    FestYboy Posts: 3,861
    Call their CS and ask...
  • FTGV
    FTGV Posts: 3,650
    FTGV wrote: »
    Interesting. Maybe the earlier versions had a single larger transformer? The transformer in that pic has separate secondary windings ,each one feeding a separate bridge rectifier for each channel.
  • FTGV
    FTGV Posts: 3,650
    dankHugzNY wrote: »
    Thank you.
    The interconnect completes the circuit between the dimensional drivers so they will reproduce the difference signal.
    Strapping the negative terminals on the amp assures it is common ground.
    Given it's origin and assuming it's working fine then it seems like a reasonable deal to me.
  • FTGV
    FTGV Posts: 3,650
    FestYboy wrote: »
    The designer is still going strong but the Forte company has been defunct for a couple of decades.
    pitdogg2 Posts: 27,220
    FTGV wrote: »
    FestYboy wrote: »
    So what are ya's sayin Fred the ring a dingy thingy may not work :):)
    why not test with a multi meter? Wouldn't that give you your answer?
  • FTGV
    FTGV Posts: 3,650
    Certainly that would confirm it. In the pic I linked to it appears the negative output (black)wires from each channel are tied to the power supply ground bus. If so that would make it common ground.
  • Dr_Wu
    Dr_Wu Posts: 356
    FTGV wrote: »
    FestYboy wrote: »
    Did Threshold buy Forte? Maybe their CS can help?
  • FTGV
    FTGV Posts: 3,650
    Forte was concieved as an offshoot of Threshold intended to develop and market lower cost(compared to Threshold) high performance products. The original founders of Threshold have long since moved on and the Forte brand was discontinued. There may still be someone on staff at the new Threshold that has knowledge of the decades old products. Nelson Pass the designer frequents Pass Labs forum at DIY Audio and would give you a definitive answer if you can track him down. However after looking at several pic's of the model 3's interior the Forte is common ground.
  • Do you guys think this amp will be okay in other ways assuming it's common ground? I couldn't find much info on it. I did read that someone was using it to drive low impedance speakers with no problem.
    I'm just trying to get a high current amp and it's either this or a NAD 2600A
  • I got it. There is one transformer.
    F1nut Posts: 51,942
    Use your DVM to test the ohms reading at the negative outputs with the amp unplugged.
  • I tested it, It's common ground. Thank you for all of your input. I also had found a thread online where Nelson Pass said he thought the output was common ground. When I read that I felt secure in taking the 150mile trip.
    This amp has opened the soundstage up incredibly. Amazing. I need bigger polks now, I only have SDA2A.
  • FTGV
    FTGV Posts: 3,650
    Congrats! Enjoy your amp. Apparently at some point in it's production life the model 3's went from using a single transformer with multiple secondaries to two separate transformers.
  • I think the one with two transformers was a modified one, in my research I came across someone talking about a modded one.
