First time setup, need some basic advice and a sub recommendation
Hopefully this is the better sub-forum for this question, if its not i apologize.
Relatively new here, have done some searching around but I have some relatively basic questions regarding the setup Ive compiled before I throw it all together this weekend.
What I have now:
Receiver: Onkyo TX-NR676
Center: Polk Lsim704c
Towers: Polk Rti A7s
Surround: Klipsch R15Ms
My main questions are,
1. is the NR676 enough? Planning to remove the jumper and Bi-Amp the A7s. I went pretty cheap and basic for my first receiver thinking I can wait on a great deal on something high end, but maybe its better to just splurge now? ( the 676 is the one part of this setup I can return/exchange)
2. What polk sub would be appropriate with this setup? I probably wont add one until close to Xmas, but Id like to add something thats a similar quality to this setup.
3. Im looking at eventually adding the FXiA6s to replace the R15ms, so i can return those to their own setup, and to complete my polk living room, that would make sense right?
Thanks!
    F1nut Posts: 51,953
    edited November 2018
    Replace the center with the CSiA6 so your front stage is timbre matched. Very important.
    Do NOT attempt to bi-amp the A7's. For starters it's not even close to bi-amping and secondly it'll drain what little power per channel is available from your AVR.
    For a sub, SVS, HSU, Rythmik.
  • tonyp063
    tonyp063 Posts: 1,136
    If, as you say, you can return/exchange the Onkyo I would.
    I'd suggest something with pre-outs so you can add a true amp down the road if you wish. The A7s will thank you.
    Which one totally depends on your budget.
  • mrloren
    mrloren Posts: 2,474
    I agree with all of the above.
    Please do not bi-amp your speakers. F1nut is 1,000% right. Best bet is to replace the brass jumper with speaker wire.
    When I did this I did a blind test on my kids. I did only one speaker. after a few days both kids were saying there is something wrong with my stereo. One speaker sounds way better than the other.
    If you can return the Onkyo, do it. Get a Yamaha, Denon or Marantz.
    Sub, SVS and HSU are great can't go wrong with either brand.
