why not use bookshelf as center channel?
hellotheworld
hellotheworld Posts: 205
edited April 2004 in Speakers
Just curious.
start with Sami's thread
http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=18244
He's going to use three RTi70 as fronts and center. So I think that would be a good idea. For example, compare R20 and CSi20, the features of R20 is better than CSi20 but R20 is much cheaper. And R20, as well as CSi20 is a perfect match with R serial. But I did not see a lot people doing this. One concern I could think is the looking. What else?:confused:
Maybe there is some special design in center speakers I do not know...
  • braveheart
    braveheart Posts: 28
    edited April 2004
    I use three RT25i speakers as my fronts and center. I had one RT25i from flea market purchase (the guy only had one) and bought two off eBay. I went this way due to my liking the sound of the 25i so much. I dont feel the need to obtain a pure center channel speaker as the panning between the three is seamless. Give it a try.
  • Sami
    Sami Posts: 4,634
    edited April 2004
    If you're using a TV then you might have problems with magnetic shielding and placement. My setup sounds great, certainly better than with either JBL S Center II or CSi20. Don't have a CSi40 to compare it with.
    Borrowing company equipment next week to calibrate. If someone in the area has a CSi40 and wants to test how they compare, they are welcome to come over with the center speaker.
  • ohskigod
    ohskigod Posts: 6,505
    edited April 2004
    i use a pair of monitor 5's for a center, with great results.
    the right bookshelf speaks will make a great center in my opinion.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • brettw22
    brettw22 Posts: 7,623
    edited April 2004
    It's pretty much an aesthetic thing, but make sure that the speaker that you use is magnetically shielded so you don't jack up your set.
