blown sub!
mekanism
mekanism Posts: 27
edited April 2004 in Car Subwoofer Talk
Well, like an idiot I blew one of my momo 12's. I just switched from the dx 12's and I wanted to see what the Momo's could do. So I cranked it up and all of a sudden one of the subs starts rattling. I just recently learned about the 40 hour break-in period, and had I known, I wouldnt have committed this stupid act. I'm running 2 C300.2's bridged for 550 Watts RMS per sub. With my previous systems I was usually underpowering the sub slightly so I never had to worry about blowing it; the subs would just distort then I new when to turn it down. Now even when I turn the system up about half way the sub rattles. I guess I will have to put the Dx's back in. Anyway, I have a question in all of this babbling. Is it possible to buy a new voice coil and fix the sub or do I need to buy a whole new one? Or can I send the sub in and have polk fix it? Any help is greatly appreciated
THERE IS NO END TO CHERRY
Post edited by mekanism on
  • AustinKP
    AustinKP Posts: 861
    edited April 2004
    I don't think they're repairable, since I don't think polk sells parts, but you might be able to return them if they're still under warranty. Where did you buy them?
    http://www.silverdragon.com/punkie/cybertusk/net.idiot.html - Read it, know it
    Alpine 9815
    Ascendant Audio Atlas 12
    2 Gallons SecondSkin Spectrum V.2
  • exalted512
    exalted512 Posts: 10,735
    edited April 2004
    you cannot repair them
    is it under warranty?
    if not, itll probably be cheaper just to buy a new one
    you mightve cracked the spyder, which is impossible to fix on a MOMO
    -Cody
  • mekanism
    mekanism Posts: 27
    edited April 2004
    I pulled the sub out today and found that the spider was completely off of the platform. I looked at the voice coil and it looked fine so I epoxyed the spider back in place. Needless to say it didnt work. I let the epoxy set up for a few hours and then put the sub back in but it now sounds really crappy. I will just have to buy another one. I am considering swithching to two 10 inch instead of 12's. The 12's dont give me the real punchy base that I'm looking for. Thanks for all of the help!;)
  • mekanism
    mekanism Posts: 27
    edited April 2004
    If I decide to stick with the 12's can I still order the older ones?
  • exalted512
    edited April 2004
    nope
    -Cody
  • mekanism
    mekanism Posts: 27
    edited April 2004
    Well thats sucks! I guess I will just buy 2 10's and redesign my spare tire enclosure. I'm limited on space anyway. Are the new subs alot better than the old ones. I was pretty dissapointed with the momo 12's that were in there. They didnt hit nearly as hard as I was expecting for running 550 watts RMS per sub. I used to have 2 MTX 10's and a 300by2 also from mtx and I remember it hitting way harder and cleaner than the polk stuff.
  • exalted512
    edited April 2004
    you had 2 momo 12s with 550 each and 2 mtx's with 300 watts each and the mtx's were louder?
    theres something wrong if thats the case...
    -Cody
  • mekanism
    mekanism Posts: 27
    edited April 2004
    Maybe my filter settings arent right on my deck. I messed with the settings earlier today and I cant seem to get the sound where I want it. I can either get decent punchy bass without low freq. bass or real low freq. bass and virtually no punch, its weird. Im running an alpine 7392. I wish my deck had presets. Could this be a box volume problem? If so I will re-check my volume or add some poly-fill.
  • exalted512
    edited April 2004
    unless your box is over 2 cubic ft i wouldnt *think* it would make the huge difference youre talking about
    as long as its around .88ft^3 you should not be having much of a problem
    are the gains on the amps low?
    -Cody
  • mekanism
    mekanism Posts: 27
    edited April 2004
    The gains are at about 3/4. Even when I turn them all the way up the subs still dont sound right. Its almost as if they arent keeping up with the song, like there is a delay. Its weird. Hopefully if I switch to 10's it will sound the way I want. I wont be able to switch for a while do to lack of funds.:(
  • exalted512
    edited April 2004
    maybe its the amp?
    have any friends that have an amp thatll do 500 watts at 4 ohms?
    -Cody
  • AustinKP
    AustinKP Posts: 861
    edited April 2004
    You mentioned that the subs sounded weird, like they weren't keeping up. Have you tried inverting the phase to them? (switching the + and - connections)
    Alpine 9815
  • mekanism
    mekanism Posts: 27
    edited April 2004
    No I havent tried that yet. I tried to use my decks sub reverse feature but it didnt work. When the bass hits the speaker moves out instead of in. I will try switching tomorrow.
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    huh?
    and i'm assuming you tried alpine's phase-reversal thingy, which does exactly the same thing as switching the wires, so if one doesn't work neither will the other.
  • mekanism
    mekanism Posts: 27
    edited April 2004
    For some reason the phase reverse feature isnt working on my deck. The funny thing is that there isnt even a reference to it in the Alpine manual. I will just try switching the wires. When I hooked it up the positive from the amp went to the positive of the sub so I dont know whats up with this. I also made sure all of the rca's were correct as well. I will recheck all of the wiring when I get a chance just to make sure.
  • exalted512
    edited April 2004
    move your ground while youre at it
    make sure theres no paint--just bare metal
    if youre using a screw, make sure its stainless and make sure youre using a lock washer on it
    -Cody
  • LittleCar_w/12s
    LittleCar_w/12s Posts: 568
    edited April 2004
    Screw Cody?
    I have a 7/16" dia bolt for my ground :D
    And those spiney electrical washers do a lot of good, but you have to crank em down real tight.
    Bolt > flatwasher > ground lug > SpineyWahser > Car > LockWasher > Nut > Nut.
    That seems to do it! (I could have welded it to the car easier...)
    -Jerry
    ___________________________
    Total cost of materials: Going up...
    Time spent: Countless Hours...
    Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
    For some things in life, you pay others to do it... For a masterpeice, do it yourself.
  • exalted512
    edited April 2004
    ive used those electrical washers sometimes, but only when the screw keeps spinning
    i dont want to use a bolt cuz i dont want to crawl underneathe the truck, i could use a seat belt bolt, but its too hard to get the paint off
    a self tapping stainless steel screw with a lock washer seems to be the easiest way for my needs
    -Cody
  • neomagus00
    edited April 2004
    it may be, a phase switch on subs is really really hard to hear. might as well try the wires anyways tho
