Terminations: Speaker and IC
daboyz
Looking for some good middle of the road terminations for diy cables. Using Mogami 3103 and 2534 wire. Looking for:
(4) pins (spring clips)
(8) nanners
(14) rca's
If anyone has some or a good place/kind to get would be awesome.
(8) nanners
(14) rca's
Douglas has some very reasonable pin ends, I've purchased some Vampire pins from him in the past IIRC. You could ask if he has any used.
How about these for nanners?
https://www.amazon.com/Nakamichi-Speaker-Terminal-Electronic-Connector/dp/B0722NZBG2/ref=sr_1_60?s=audio-video-accessories&ie=UTF8&qid=1539795885&sr=1-60&keywords=banana+plugs+copper
or if you want to spend a little more
https://www.amazon.com/Audioquest-SureGrip-100-BFA-Gold/dp/B011AAU5UI/ref=sr_1_22?s=audio-video-accessories&ie=UTF8&qid=1539796063&sr=1-22&keywords=banana+plugs+copper
I have used the BFA set screw banana & crimp spades from Ram Electronics in the past. They have pins as well, both set screw type and solder. Nice connectors for not a lot of dough.
https://ramelectronics.net/speaker-connectors.aspx
I found the Sewell Strike bananas have excellent wire contact, low profile, easy to install, and are very budget friendly.
https://www.avoutlet.com/cables-connectors/av-connectors/audio/furez-r10bcs/
Dave look through here. many good things one of my go to sites
