Monitor 7A Xovr ?
Pauly
Pauly Posts: 4,519
edited April 2004 in Speakers
As you can see attached couple of the wires came loose...maybe in shipping or damage already done dunno, but can i re-solder them back without and will they work? Thanks
Life without music would♭
  • Pauly
    Pauly Posts: 4,519
    edited April 2004
    and
  • faster100
    faster100 Posts: 6,124
    edited April 2004
    heck yeah you can resolder them... you can even use wire to splice it back together, as long as its as thick as the wire coming from the capacitor or what not.. easy fix
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2004
    Don't use wire to patch it, you will change the DC inductance, there by changing the overall Q of the drivers, which will then audibly alter the sound of the speaker itself.
    Solder it yourself, or get someone else to.
    Cheers,
    Russ
  • faster100
    edited April 2004
    well it looks like some of the leads are broke off, so i wouldnt think a 1" piece of wire would alter the resistence.... maybe im wrong, in which case i guess you should get new componets to do it properly...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • RuSsMaN
    edited April 2004
    Well, its not so important on the Cap you see in the first picture, but the inductor in the second picture is made of a certain length AND guage of wire, wrapped around probably an iron core. The value of that inductor is based on the guage and length of the wire wrapped around it.
    You see where I'm headed, and that precise measurement could be altered? Just FYI, thats all.
    You do bring up a point though, if I was faced with the same situation, I would repair the inductor connection, and buy new, upgraded caps and resistors (of the same value), and upgrade them, while I'm there anyway.
    Cheers,
    Russ
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited April 2004
    I agree, such short wire repair I don't think would change anything. The wire would be only add to end feed wire, it wouldn't change the Coil mh rating.
    QUOTE]Originally posted by faster100
    well it looks like some of the leads are broke off, so i wouldnt think a 1" piece of wire would alter the resistence.... maybe im wrong, in which case i guess you should get new componets to do it properly... [/QUOTE]
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • RuSsMaN
    edited April 2004
    I think it's a fact that it would change, but I guess the real question is would it change enough to 'bother' you at the end of the day, sound wise.
    It would F with me regardless, so I'd do it right the first time, rather than second guess it later.
    Cheers,
    Russ
  • disneyjoe7
    edited April 2004
    Ok, if you think so. Such a small wire added to end, I wouldn't think so. But been known to be wrong.
    BTW, looking at that picture I wonder if he would even need any wire.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • RuSsMaN
    edited April 2004
    Ed Zachry.
    Cheers,
    Russ
  • faster100
    edited April 2004
    Yes i do agree, if its a coil.. it can change values... i used to be into Cb/ham radios alot.. and when i tuned up the wattage and modulation, we would spread apart the coils in the rear of the units by the output transisters to increas modulation swing and overall wattage... per the old man i knew told me about... and i watched for hours on end learning about them.... if its broke off, change it.. the caps as said should be ok with a wire extension to get you by.....
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • disneyjoe7
    edited April 2004
    Thanks, may have learned something new today.
    Or I was told something 2 times, but this one sunk in?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
