Power
I have polk monitor 75t speakers they say 20 to 275 watts... I running 120 watts to each on my hk 3490.. My? Is will they play louder and sound better if I use a pa audio amp 300 rms to each
Best Answers
  • lightman1
    lightman1 Posts: 10,796
    Answer ✓
    afterburnt wrote: »
    "all shut eyes aint sleep and all goodbyes aint gone"
    Good to have you back Bruce ;)
    tonyb Posts: 33,072
    Answer ✓
    Guys, your wasting your time. He doesn't care about sound quality, so what's the point of continuing. Get pro stuff and bleed your ears out dude. Done also.
  • verb
    verb Posts: 10,176
    Answer ✓
    Yep
    Viking64 Posts: 7,549
    Answer ✓
    I still think this thread can be fun, so here is a donkey in a boat.
  • Justinthomas1977
    Justinthomas1977 Posts: 35
    Answer ✓
    Mad power and an equal amount of sound quality. There was a small amount of buzz about this amp on some Home Audio boards. Some people said such an inexpensive amp just couldn't sound good and had no place in a Home Audio rig. Funny thing is, this was said by people who hadn't heard it. Those who heard it in their systems were amazed at what they heard. Even more impressive is that it delivers sonic performace rivaling that of MUCH more expensive audiophile amps. I'm driving a pair of Magnepans which are VERY revealing speakers and they reveal this amp to be wonderfully powerful and transparent.
    The bass is clean, tight and powerfull. The mids are totally transparent. The highs are very detailed, clear and extended. Whatever your source supplies, it will be faithfully passed on to your speakers. I've been an audio enthusiast for over thirty-five years and these ears know good sound when they hear it. Detail, dynamics and headroom. This amp has these by the boat load. Listen for any sonic warts or shortcommings and you won't hear any. Often, high end speakers present difficult loads, have low sensitivity or just plain don't sound good unless driven by a powerfull amp with plenty of headroom. Usually these amps are very expensive. With a EP1500, you can drive these speakers without going broke to do so. If you're going to seperates for a music system or bypassing your HT receiver's onboard amps to get big power, this is your ticket. A big, high quality SS amp just makes speakers play better!
  • Justinthomas1977
    Answer ✓
    Lol OK bye I'm leaving
    F1nut Posts: 51,763
    Answer ✓
    You copied that post from Audio Review, it's one of two reviews......LOL
  • Justinthomas1977
    edited September 2018 Answer ✓
    How but this.. Is it Better then my 120 wpc hk 3490 receiver ki83po61hxcm.jpg
    pitdogg2 Posts: 27,045
    Answer ✓
    I can't tell diff frm a sony receiver frm a marantz or onkyo
    It's in the spelling.....
    mhardy6647 Posts: 35,006
    Answer ✓
    Answer ✓
    I keep seeing comments on the second page of this thread, then they disappear. Vanilla is open source software and it needs someone to babysit it. Is there even a webmaster here? :p
  • afterburnt
    afterburnt Posts: 7,892
    Answer ✓
    It all fooed up
    F1nut Posts: 51,763
    edited October 2018 Answer ✓
    Something is messed up. The OP has somehow managed to mark 3 of his own posts "accepted answer".....lol
  • codycatalist
    codycatalist Posts: 2,662
    I would refer you to the last quote on my signature...because I have been there too. I mean not this argumentative but I have been there.
  • Justinthomas1977
    Answer ✓
    FestYboy wrote: »
    Like I said Justin, look at eBay to save some (a lot) of money on the 545...
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/223159318137
    I'm in Canada your dollar is diff then shipping I think 300 is cheap
«13
Answers
  • mlistens03
    mlistens03 Posts: 2,767
    They’ll sound better on the H&K, but not because of the power rating. The H&K is a better amp, designed for sound quality, whereas the pro amp is designed to be able to take lots of abuse, such as running at 100% power for extended periods of time.
    Take this advice from a guy who bought a pro amp, and is now stuck with it. :)
    The higher number of watts is less a factor than the quality of watts, and amps (current) even more so. Most PA amps sacrifice sound quality for ability to provide volume in larger rooms (venues as apposed to home listening).
    F1nut Posts: 51,763
    No
  • BlueFox
    BlueFox Posts: 15,251
    Short, sweet, to the point, and correct. LOL.
  • Viking64 wrote: »
    These speakers will clip and blow tweets when I put up vol to high so I thought more power will solve this
  • mlistens03 wrote: »
    How much more crappy did they sound..? And how bout 300w to each with home amp but they wayyyyy more money
    Well, that's another question altogether. The answer is likely "yes" that this might solve clipping issues. Will it play LOUDER? Most likely. Will it sound BETTER? Very unlikely.
    Loud. Good sound. Inexpensive. Pick 2 of the 3.
    F1nut Posts: 51,763
    F1nut Posts: 51,763
    Viking64 wrote: »
    First lesson, all watts are not created equal.
    Second lesson, to increase the volume level by 3dB it takes twice the power. Going from your 120wpc amp to a 300wpc amp will gain you roughly 3.5dB.
    Third lesson, one can make just about any amp clip by turning up the volume too far.
    Fourth lesson, a cheap amp gets you bad sound.
    Fifth lesson, a good amp costs money.
    tonyb Posts: 33,072
    6th lesson....if you like it louder, you bought the wrong speakers. Buy speakers that can handle that loudness like PA speakers, Crappier sound, but they'll go louder.
    7th lesson....everything has it's limits. Turn the volume knob down if you don't want to keep blowing tweets.
    8th lesson....those "recommended watts" on the back of speakers mean little.
    9th lesson....get your read on and learn about audio. More to it than just buying a pair of speakers and cranking on the volume knob.
  • verb
    verb Posts: 10,176
    10th lesson, take heed to the advice here. I did, but must admit took a lot longer than 24hours to get 9 lessons! You must be in the condensed course!
    Welcome Justin! Hang around, lots of good advice here, and information.
    My tenure here on CP has been very informative, and fun! :smile:
  • mrloren
    mrloren Posts: 2,474
    If you want loud, get Cerwin Vega. About all they are good for is going very loud.
    Now if you want sound quality please listen to these people.
  • I'm done here. And I no all this stuff ppl are telling me I been in home and car audio long time I just have never heard pro audio stuff ever in home audio.. And this a polk audio forum polk ain't that great of a speaker I bought for the cheap price.. In other high quality forms ppl say some of the pro stuff sounds good... I'm looking for clean and loud I don't care about Sq hell I think cerwin Vegas sound good any ways thx I'm finished here
  • Oh and I sold my klipsch rf82s I miss those they got loud and had high sensitivity only sold cuz they got all banged up
    F1nut Posts: 51,763
    The scary thing is that he walks among us. There should be an IQ test given before someone can join here.
  • polrbehr
    polrbehr Posts: 2,842
    He plays a good game of golf though, have to give credit where it's due ;)
    Seriously though, stick around, it's not that bad here and you can get some really solid
    advice. NO ONE will intentionally steer you wrong.
  • Milito
    Milito Posts: 2,003
    Just because they tell you what you don't want to hear, doesn't mean it's wrong. There are some people here who know a lot about audio.
  • Justinthomas1977
    Will this rotel 70wpc be a down grade from my hk 3490 120wpc louder sound better? 9zmfagjk11v0.jpg
  • cfrizz
    cfrizz Posts: 13,415
    Rotel makes very good amps. All things being equal at the very least it will be equal to the HK since the only job that the Rotel has to do is power your speakers. Go for it.
    But, but... then y'all wouldn't have me...
    umm...
    wait...
    OK, I see your point.
  • mrloren
    My Teen setup was 15" Cerwin Vega (D9 I think) and Polk bookshelf speakers. When I wanted it loud I used the Vegas, when I wanted SQ I used the Polks.
    Car audio to home audio is a a lot different. Cars are small compared to homes. A lot more space to fill in a home.
    A receiver has a lot to task the power supply with. As in car audio you get better cleaner power from a separate amp.
  • afterburnt
  • Wow ppl on forms got lit of time on there hands... I can't tell diff frm a sony receiver frm a marantz or onkyo
  • BlueFox
    Sounds like a personal problem.
    Oh dear.
  • verb
    verb Posts: 10,176
    Justin Justin Justin. Listen and learn. Nice and easy. Don’t try and go toe to toe with these guys, they really know what they’re talking about. I’m a testimony to their tutelage. Come in with open mindedness, not fists clenched and swinging. Read my threads. You too can take a similar journey.
