MMC650 - It says 6-1/2 on the box BUT...
SF_VR6
I purchased the 6-1/2 MMC650
I have a 1998 VW GTI VR6 with stock 6-1/2 speakers. I had 6-1/2 MB Quartz which fit perfectly.
The MMC650s would not fit as they were 6-1/4 in diameter. The screw wholes were completely off.
Why are the speakers smaller than the advertised 6-1/2?
The holes were even smaller in diameter and I could find no way for the speakers to be mounted.
Can anyone shed some light on why these will not drop in and fit? Instruction manual did not show how to mount into most cars door panel cut out.
Any insight greatly appreciated .
DL
Post edited by SF_VR6 on
Welcome to the Club...
While it's possible you'll get an answer to your post here, the Home Audio area, your odds will improve down in Car Audio. Its further down the Main Menu.
Good Luck...More later,
Tour...
Vox Copuli
