Volume needs to be set too high
louman67
louman67 Posts: 1
edited January 2002 in Technical/Setup
The volume on my receiver (Yamaha RX-V800) needs to be set to 50% or higher to have a reasonable sound level. I have the RM6600 system with the PSW250 sub, connected to it. Anyone know if this is normal or is something wrong?
Post edited by louman67 on
  • trubluluc
    trubluluc Posts: 2,067
    edited January 2002
    Depending on the movie, I set the volume between
    40 and 50 most of the time. Have gone as high as 35. Thats plenty loud enough for me.
    I also have a yamaha.
    -luc
  • trubluluc
    edited January 2002
  • TrappedUnder Ice
    TrappedUnder Ice Posts: 975
    edited January 2002
    Thats weird... I have the 795a... model prior to your 800 and I usualy watch it at 25-35% volume.. 50% would be way too loud. Not sure what is up with your system..??? My other yammie was the same way as my 795a... maybe check your settings?
    BTW... I have a pretty large room to fill too
  • crystal-clear
    crystal-clear Posts: 19
    edited January 2002
    I have a yamaha rxv-995 and the knob on mine is aroumd the 35-40 mark, and this is pretty loud. On mine there is a main level setting...-10db, or Normal. Maybe yours has this too. ?? Mine is set to -10db and is very loud around the 35-40 mark.
    PS-I am using external amps, not the internal.
    Yamaha has great customer service, maybe they can help you solve the problem, if not, I will be glad to try, or at least somebody on this forum can help you, concidering all the smart and clever people that have helped me.
