Monitor 70's
What's the difference between the 70's and the series 2? Will they still match? Also was thinking using one as center channel, laying on it's side. Think it would work? Thanks
Panny 8000 project
Oppo 103D
Fronts- Monitor 70's
Upper fronts- Monitor 30's
Surrounds- Monitor 50's
Backs- Monitor 40's
Center-CS 350
Sub- SVS PB 2000
Onkyo 607[back up]
  • mdaudioguy
    mdaudioguy Posts: 5,164
    edited September 2018
    Would it work to lay one on its side? Yes. Would it sound (or even look) good? IMO, no.
    Simply put, they're not engineered to perform that way.
  • woodhead 2
    Okay, thanks.
    Panny 8000 project
    Oppo 103D
    Backs- Monitor 40's
    Center-CS 350
    Sub- SVS PB 2000
    Onkyo 607[back up]
  • hochpt21
    hochpt21 Posts: 5,423
    The front of the speaker (if the grill is off) on some Monitor 70's are silver and some are black. I'm not sure if that translates exactly to series 1 vs 2, but something to look out for.
